Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Wireless connection how do I connect the wireless function to my laptop
  • 73 Answers
Typically this is done using the software disk that came with the printer. The disk will help the wireless connection coordinate with the laptop and will also install the driver.
Posted on Feb 08, 2009
What function keys do I use to get a wireless connection?
Have you tried using the function keys? There is a row of keys at the top labeled F1 though F12, they also have symbols. Find the one that looks like one of these, press and hold the function enable key that is like at the bottom of your keyboard and then select the button you found in the top row.
Nov 20, 2011 | Computers & Internet
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
Brother i have just opened a wireless network but my wireless network is not working properly. Can u plz contact me for some help i shall be very thank full to you if u do this favour for me. Thanks...
Troubleshooting issues with wireless connectivity can be tricky. There are a bevy of potential causes for drops in the connection, slow-downs in throughput and sporadic signal loss. As such, it's best to take a shotgun approach, throwing a number of possible fixes at the problem and hoping one sticks.
Check if your laptop's wireless switch or button is turn on - look around the laptop in front, back or sides. Sometimes you might touch to turn off accidently and you don't know. Many laptops have the wireless light indicator, check if the wireless light is on and blinking.
Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the wireless, which is to control the wireless connection of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, touchpad etc. You will need to hold down the Fn + F8 combination keys together, in this example the Toshiba laptop's wireless setting.
  • 3
    Check Network connections; make sure the laptop connection is not 'disabled'. It should has the gray color if it's disabled. Right click on it and enable it.
  • 4
    If none of the above works, you will need to enable the Wireless Zero Configuration in services.msc (type this in from Run command), or you can see it this way: Right click My Computer -> Manage -> Services and Applications -> Services.
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJNokX7
  • 2
  • 3
  • 4
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJ8lq45
    May 07, 2011 | Computers & Internet
    I have somehow disabled the wireless capability. do you know the function key combination to enable it?
    check on the edges of your laptop, there might be a slide switch to enable wireless connection.
    set up a wireless connection by plugging in first the network cable.
    select wireless or wlan connection
    follow the process
    reset your router
    restart your computer
    enjoy wireless networking
    Jan 27, 2011 | Acer Aspire 6930-6771 Laptop
    How do i get my netbook to connect to the internet/ what wireless device can I get to make it work
    You need to have an active internet connection with a wireless gateway to connect to the "net" wirelessly. You also need to have a wireless device installed in your laptop. The device in your laptop usually has a switch to turn it off and on. This switch maybe on the side of the laptop or may be on one of the keyboard function keys, either way, the wireless support lamp should be on or green for the wireless system to work on the laptop.
    If you do not have an active wireless internet connection, you cannot connect to the net although you should be able to connect to a unsecured wireless network which is in range of your laptop ( like in a shopping centre).
    If your laptop does not have a wireless device fitted, visit your local computer shop to ask what they have available and at what cost.
    Jan 14, 2011 | Sylvania G-Netbook
    Wireless router
    You need a network card that is functioning to connect to anything.
    If your network card in the desktop stops functioning, you will need to replace it (or, if it's built into the motherboard, add a card).
    Unless you have a wireless card also installed, you cannot connect wirelessly.
    Dec 19, 2009 | Dell OptiPlex GX260 PC Desktop
    I was connected to the Internet using my laptop (my desk pc was also connected). Got booted off. Windows diagnostics could not repair. Called ISP and they rebooted my modem. Desk pc connected to Internet,...
    Was it a wireless connection?
    Perhaps you have accidentally switched off the wireless function? Many laptops have a wireless on/off switch, either as a pushbutton above the keyboard, or a slider somewhere on the side of the laptop case. Consult your laptop's manual if you can't find it.
    Nov 14, 2009 | Toshiba Satellite L355-S7811 Notebook
    Hi, I have a toshiba windows XP laptop which stopped connecting to wireless network(WEP) .But it connects to network through LAN with ethernet cable .Laptop wireless finds my network but does not connect(...
    Check your security settings would be a good start. Have you checked to see if XP uses WEP to authenticate? (it should do this automatically but sometimes it doesn't)
    Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
    Wireless connection problem with Medion MIM 2120
    hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
    Feb 01, 2009 | Medion md40298 Notebook
    Internet Connection
    hi, in :My network places" u can see this wireless local area connection, on the right hand side menu, there is an option to creat a new connection, clickon it and go step by step, u will figure it out.. keep handy ur ISP network details.. let me know
    Jan 13, 2008 | IBM ThinkPad T20 2647 Notebook
    HP Officejet Pro L7580 All-In-One InkJet Printer Logo
    95 people viewed this question
    Seeker5211
    Seeker5211
