Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
My blackberry world rollerball moves but none of my buttons click
I can roll the rollerball but it will not click and neither will any of the other buttons, I have removed the battery multiple times but it has not helped.
  • laurahall28 Feb 11, 2009
    i have the same problem, did you get an answer on this issue? my numbers also show letters instead. Its like the numbers are completly locked up.
I would send it back to the manufacturer. apparently the trackball has a problem and it needs to get fixed. or u can go to a blackberry specialist and tweak the trackball so itll work better
Posted on Feb 23, 2009
Rollerball will move, but won't click to activate applications. Nor will the buttons work to answer or turn phone on/off? The side buttons won't work either. All other aspects of the phone are...
my friend it is easy just open ur phone and clean ur rollerball u find calceur white.this because ur mobile infected by water .and tel m later
Jan 04, 2010 | RIM Blackberry Curve 8300
Rollerball not working
On the BB need to have the board service....this will solve the problem on your 8800 Blackberry.
the roll ball......on the need to have the pad on the board replaced so take it to a professional mobile technician and have that done.
Jan 03, 2008 | RIM BlackBerry 8800
How to fix a faulty Blackberry rollerball/trackball
There are a few relatively simple solutions to fixing a faulty Blackberry rollerball/trackball.
Compressed Air
Spraying some compressed air on the ball and round the sides of the ball can sometimes loosen the compacted dirt & dust on the rolling mechanism.
You can pick up compressed air from your local hardware store.
Spray a tiny amount of WD40 on a cotton bud and rub it onto the rollerball. This can free up the mechanism and lubricate it.
Removing and Cleaning the Rollerball/Trackball
  1. Using a small flathead screw driver gently prise the silver ring around the rollerball from the top (be extremely careful as the catches are made of plastic and can break easily)
  2. The rollerball module should come out with easy
  3. Using a clean paint brush, gently brush the inside of the Blackberry where the module came from
  4. Using a toothbrush clean the rollerball module gently around the rollers on the underside and also clean the actual rollerball
  5. When replacing the rollerball module it will only fit one way so don't worry about putting it in upside down
  6. There are three plastic catches on the silver ring, there should be one at the bottom & two at the top. Line them up on the phone and press it back in place gently.
Replacing the rollerball/trackball
Sometimes the mechanism or the rollerball can be come damaged and cleaning will not solve the problem. In this case you can replace the rollerball by following the instructions above about cleaning and purchase a replacement rollerball from eBay or one of the other countless online stores that see Blackberry parts.
I would always recommend that you buy genuine Blackberry replacement parts as these are usually of a higher quality than copies.
on Dec 18, 2009 | Cell Phones
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
My rollerball won't click.
I'm having the same problem with this. One of my friends and a Att worker have suggested that replacing the Rollerball with a new one which can be bought off Ebay for 5 or 6 bucks can fix the problem. If that does't work then check to see if water damage has taken place, if any moisture has gotten to the phone it may be that. Other then replacing the rollerball i have no other solution.
Apr 17, 2009 | RIM BlackBerry Pearl 8100
The rollerball on my blackberry pearl does not move down only up
Your rollerball needs a clean.
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry’s trackball should be back working now.
There are pictures of how to do this on "other" forums.
Dec 04, 2008 | RIM BlackBerry Pearl 8100
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
Try, they will have links to buy parts, also is great too.
May 05, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM will admit, its a known issue with the blackberry was the first blackberry with a front trackball and so there is a design flaw that dust will get in here and prevent the magnets from moving around inside.
the little silver rim is acutally designed to be taken off so you can clean inside. take an embrodery needle, and put it under the silver rim by the TY button on the keypad....once this pops off, there is the ball and there are 2 more silver rims inside along with 4 magnets. remember how you take this apart, cause if you dont, then this will void any warrenty your phone might have.
in order to clean this, soak the ball in rubbing alchohol and take a cotten ended Q-tip with rubbing alchohol and damp it a little bit and clean it real well.....its also nice preventative doing this regularly...,. (not taking the ball out, but just cleaning the rim and ball about once every other day or so....)
Dec 30, 2007 | RIM BlackBerry Pearl 8100
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
586 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
