Question about Husqvarna Lily 540 and 550
Bobbin does not wind all the way up
Lily Husqvarna Viking 540 machine bobbin only winds half way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Posted on Apr 07, 2010
    Novelist:
  • Husqvarna Expert
  • 371 Answers
I'm assuming the bobbin winding mechanism is on the upper portion of the machine (right hand side). There should be a white "knob" next to the bobbin when engaged for rewinding. The "knob" detects when the spool is full and stops the rewinding. It should be able to be pulled straight out toward you. Adjust the "knob" until it allows the spool to fill completely. You can either remove it and reattach or just gently twist it in place. If you gently push the "knob" to the left you can feel it release the rewinding mechanism. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Posted on Sep 24, 2009
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
Bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
Jun 15, 2010 | Husqvarna Lily 540 and 550
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
No Know- How
Try ebay or contact an authorized Husqvarna Viking dealer. They should be able to order you a replacement manual. Check Husqvarna Viking website for dealer closest too you.
Mar 22, 2009 | Husqvarna Lily 540 and 550
I filled the Bobbin, now how do I get it to go back to sewing
Something didn't click back in place when you removed the bobbin from the winding mechanism. Try winding another bobbin. Make sure it stops, then remove it. If the problem continues, take it to an authorized Husqvarna Viking dealer. They should still be able to take a look at it. Check Husqvarna Viking website for dealer closest too you.
Dec 16, 2008 | Husqvarna Viking 1
Bobbin won't wind
The bobbin rewind unit needs to be inspected. In order to do that the covers have to be removed. It could be the wiring to the board may be disconnected or the rewind unit is just broken and needs to be replaced. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jul 25, 2008 | Husqvarna Designer I
Husqvarna lily 540
bobbin wound too tight. remove thread first then pull off bobbin.
Jun 02, 2008 | Husqvarna Lily 540 and 550
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
237 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
