Question about Maytag MGS5770 Gas Kitchen Range
How do I calibrate the oven temp?
It does not seem like the oven is cooking properly at the set temperature. Cook time ALWAYS needs to be extended.
  • 360 Answers
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Posted on Feb 08, 2009
Why doesn't it heat to set temperature?
Hello. In most ovens with an electronic control, the temperature is regulated by 2 things--the sensor and the oven control board. The sensor is simply an electrically resistive device that changes resistance as the temperature increases or decreases. It is connected to the main control board by 2 wires(just a "pigtail") and the main board is supposed to be calibrated to adjust properly. Most control boards have a built-in program by which you can adjust the calibration +/- 35 degrees. If your oven is outside that range, and you're sure that the sensor is good, the connections are good, etc., then the oven control board temp control circuit has gone bad. Keep in mind, when you turn on an electronically controlled oven, the first time it heats up is USUALLY hotter by about 50 degrees--this allows the floor, walls, and ceiling to reach proper temperature. This is called the initial spike. In gas ovens, the user must wait approximately 8-10 minutes AFTER the oven beeps to cook anything. In an exposed-element electric oven, the user waits approximately 10-15 minutes after the beep. In the hidden bake element models, waiting 20-25 minutes after the beep is normal!
Also, keep in mind, ovens can have 60 degree temp swings higher and lower(as long as the midpoint is close to the chosen temp) I hope I've helped you!
Sep 15, 2015 | Kitchen Ranges
F2 Error when using the oven GE XL44 Gas Range
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 23, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Kenmore Electric oven is not getting up to the proper temperature
Look closely at your knob. I bet it is cracked.
Jun 10, 2009 | Kitchen Ranges
Oven consistently burns food no matter what temperature setting
Well, must confess, we had this problem once, after cleaning all the knobs. We put them back, reversing the two temp knobs. The correct placement, we found, was the left oven knob, since it is not self cleaning, does not have the word CLEAN. This is the far left knob. Next, from left to right, appearing very simmilar, also with temps 200 to 500, is the right oven temp knob, which does say CLEAN. Third from left is the right oven function knob, with CLEAN, Time Cook, etc, and no temp numbers. Hope your fix is this simple. Hope your cooking is looking good cooking.
Dec 07, 2008 | Jenn-Air Kitchen Ranges
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
When I cook or bake in my electric oven things are never done in the recommended cooking time. The heating element is working fine.
hi. thanks for the question. does the door seal properly. check that..sometimes the calibration will go off. what i tell my customers to do is.buy a small oven thermometer, that you hang from the racks . then try the oven at 350 degrees .then look at the oven thermometer . and see what the difference is. so lf ,the oven temp is a bit low .cook at 375. degrees. that will make up the difference . no parts needed. cheap fix. thanks the appliance doc
Sep 28, 2008 | Kitchen Ranges
Oven will not bake properly
as i have said before cook times are only a guide as all ranges in different locations cook differently! get to know your stove
Dec 10, 2007 | Frigidaire GLEFM385D Electric Kitchen...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Maytag MGS5770 Gas Kitchen Range Logo
2,333 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
