Question about Bowflex TC3000 Treadclimber
Error code E5-5
Our machinbe sounds like a freight train and sets off a code E5-5 or ES-S can't tell them apart. anybody know why? when it gets the message it turns off the machine we have a TC3000
  • 1 more comment
  • jsaceric Mar 24, 2009
    I am having the same problem with mine!!
  • brussbjrusse Apr 09, 2009
    I am going through the same issue, Display is telling me I have a bad speed sensor after running the machine through th recalibration mode. New speed sensor is around 5 $ and tech support line they commonly go bad. Good luck, on the upside they are easy to replace.
  • 4cmom Apr 30, 2009
    I am having the same problem. I called and the rep told me the back roller is bad. After several hours of repairing the machine myself, it still is not working. Bowflex should be ashamed of selling a product that needs constant reapairs!!!
I didn't use mine for several years then just started again. It stopped after 15 minutes so I read the manual and used a silcone lubricant on/under the treads as recommended. That definitely helped and it was working again quite well for about a week or two. Now I get the error 5 again. Wondering if I needed to add MORE lubricant the first time so I am going to do it again tonight. Maybe it is the roller pully that needs the lubricant. Who knows. I just want it to work!! I am determined. :)
-becky
Posted on Mar 23, 2010
Why is my polar express o gauge train set chugging not working?
There are different versions of the Berkshire 2-8-4 locomotive that comes with these sets and the process of activating chuff sound on them varies depending on which version of locomotive you have.So in order to help you I need to know which one it is. Do you have the model number of your set?
Dec 30, 2017 | Polar Express Crafts & Hobbies
2006 Freightliner 60 series Detroit throwing the following codes... 108, 117. Can anybody help tell me what they mean.
these are specific detroit / freight liner codes
take it to a service dealer as the downtime costs will be more than fixing the fault quickly
Apr 20, 2015 | Cars & Trucks
We have changed the batteries 3 times in both controller and engine. We have sound and light on engines but no movement of engine. What can we do to troubleshoot? 71-1163-250 manf. China 7/09
I bought this set for my grandson and had no problem. The booklet says to make sure all screws on the battery compartments are tight, and they are fresh batteries installed properly. Then i saw this post on another website:
http://screamingreviews.com/lionel-little-lines-freight-set-review-this-toy-train-christmas-present-was-a-big-hit-with-the-kids/
"The plastic train was another matter. I went through several sets of batteries trying to get the thing to run. No matter what I did it wouldn't run right. It didn't do anything. Then I took it apart and found that there was a sticker that indicated which way the batteries were supposed to go in and the sticker had somehow become lodged covering the battery contact on the inside. This is why nothing worked. Once I removed that sticker and replaced the batteries everything worked perfectly."
Look carefully at all contact surfaces to see if anything plast ic blocking the metal.
If all else fails and you can't return it, I would be interested in buying more track for my grandson! kohls@juno.com
Dec 31, 2010 | Lionel Little Lines Train Play Set...
Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
Jul 06, 2009 | Hit Thomas and Friends Trackmaster...
Lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Dec 17, 2008 | Lionel New Haven Freight Train Set
JVM ERROR 513
I have my Blackberry 100 and I have JVM Error 513 reset.
I have the desktop manager and when I plug in my phone to the pc and try to instal the softwere my pc can't find USB.
Does anybody know what to do in this situation??
Oct 16, 2008 | RIM BlackBerry 8800
Bowflex TC3000 Treadclimber Logo
1,010 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
