Question about Denon DCM-5001 100-Disc CD Changer
Denon DCM 5000 error code
Denon DCM 5000 displays message "Disk Sense" then displays the error code "012 000." The disk load fine and the machine tries to play the CD but then I get this error code. Any suggestions as what will fix this problem? Thanks.
  • audiowalker0 Feb 16, 2009
    Thank You Mahario!
  • Anonymous Mar 27, 2014
    No display
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Posted on Feb 16, 2009
How do you get to the lens for cleaning
There is special disk for sale for cleaning lenses. Otherwise you will have to take apart your changer to clean lenses. If you have some experience and tools - you'll be fine.
Aug 19, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Error 4836 479 Denon DCM 5000
the slider has to be manually pressed to the backside of the cd changer, than it will work again
May 11, 2008 | Denon Audio Players & Recorders
Denon 2910 CD player malfunctions
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Nov 04, 2007 | Denon DVD-2910 DVD Player
Denon DCM-5001 100-Disc CD Changer Logo
479 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
