Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Can I upgrade to a new motherboard with existing components?
My son is recommending that I build a new computer from the ground up. I have a 2001 Gateway which is old. Would you recommend just buying a new motherboard, memory and maybe a bigger hard drive and using the box and other components? What else would I need? I'm running XP (slowly) and have a graphics accelerator card already, CD with burner and DVD player. Seems dumb to buy all the same stuff again. What do you suggest?
  • 70 Answers
You may not be able to upgrade the system without also replacing the power supply... the current one may not have enough power.
You would also need to match the CPU to the motherboard. If you can't find a motherboard that will use your current CPU, you'll have to add that to the list.
I would also be concerned about cooling... newer CPUs run hotter and need good cooling, so a new(er) case may be in order.
Your graphics card would also have to match the slots on the new motherboard. Almost all are now coming with PCI Express slots, replacing AGP from just a few years ago.
At this point you are almost to the point of a new machine... physically and cost wise.
On the good side, you could still use your existing hard drive, CD/DVD, etc...
Posted on Feb 08, 2009
Sound from headphones on computer terrible
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You will need to open up your computer to check the back of the input headphones plug look for dusty and bad soldering or loose connections. b> Computer Headphone Jack Has Fuzzy Noise b> When building a computer system, making headphone and microphone jacks are one area where computer manufacturers use the lowest-cost parts. When it comes to computer audio, no perceivable difference in sound quality exists between that of ordinary parts and higher quality ones. Very low-quality parts, or parts that are installed with sub-par wiring, however, can lead to fuzzy sounds and static on headphones.
Symptoms and Component Isolation Start the diagnosis by using different headphones in the jack. If the fuzzy noise or static problem persists over multiple headphones, even if it doesn't happen with all of them, it's probably within the jack on the computer. This is also probably the case if the static increases when you do other things on the computer, like dragging windows around on screen with your mouse, then stops when you stop dragging windows. Causes b> The leading cause of headphone jack static is electromagnetic interference from other components in the computer's case. When electrical devices draw current, they also generate a magnetic field. Overlapping magnetic fields cause static. To combat this effect, the manufacturer provides for the components on motherboards to be grounded - the wiring from the microphone jack will have an extra lead that goes directly to a grounding agent. When your computer headphone jack has a fuzzy sound, or static, the ultimate cause is usually bad grounding on the wiring that the jack plugs into. Rewiring The Jack b> If you're comfortable with a soldering iron, and know enough about electronics and wiring, you can remove the wire to your microphone jack and put in one with heavier shielding, or a better ground. If you're not comfortable with this, a computer repair shop may be willing to tackle this for you; the actual cost in labor is about an hour to an hour and a half of labor time. It may be less if the shop technician is familiar with this sort of repair, as opposed to only knowing how to swap cards on the motherboard. Using Different Ports for Audio Cheaper alternatives exist than rewiring the headphone jack on your motherboard. One of them is to put in a dedicated sound card - which will cost $15 or so, and you may have a compatible one from an old computer that can be scavenged. This will require researching the make and manufacturer of the card to download compatible drivers off the internet, and then installing them on your computer. If you have an unused USB port, the easiest solution is a pair of USB headphones. This has the advantage of working with future hardware as well.
How to reduce static in my audio
Feb 27, 2013 | Computers & Internet
I have a copy of windows vista . its on my computer but i added windows7 upgrade. can i use vista on another computer i am going to build for my son?
Legally you cannot do this as the license is being used on your original computer, Sorry. You can try and see if it activates. You may be lucky. Good Luck.
Jan 21, 2012 | Foxconn A88GMV AM3 AMD 880G HDMI Micro ATX...
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one:
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
I install a new motherboard for a dell studio 1735, the laptop start but in a minute after starting the laptop is off
New motherboards replaced on computers starts with several observations as regular anticipations. First the computer has to get adjusted to the new circuit arrangements. Assume that the new motherboard had all the component structures least required to malfunction. Once installed, the power circuits have to get adjusted depending on the type of components that have been installed on the new board. For example, the computer requires searching to ascertain the new means to achieving user expectation soon after configuration onto new board of circuits. The processes of the computers reconfigurations includes search every components parts comprise the new mother board. A start at power on performs basic input output devices inspections of the interior components of sound, video, storage, heating, clocks, cables, programs, and finally the external connected ports. Once the computer ascertains that the new system has the requisite details to perform desirable, it is usual to shut down automatically to restart to achieve the users expected installations. Also, the basic input output search may have discovered errors during the process and was incapable of power shutting immediately but provides the extensive nature to attaining an entire diagnosis until displaying momentarily before power shutting completely. Once the computer was able to search the entire new circuits to arrive at users momentary interface display is indication that every component is appropriate only least has the extensive capacity to display extensively. Computer automatic shut down has three possible explanations. First, the program system also known as operating system is incompatible on the computer. Usually the new mother board contains remnants of the operating system of the computer from which was extracted. Since the motherboard least contains a hard storage drive that has the operating system programs, installing a new motherboard on an old computer still with hard storage drive continues to have old programs requesting to communicate with a new circuit board. Usually, two separate operating systems are least compatible to each other where the motherboard would have for example windows 2000 installed on a windows 98 computer still with remnant hard disk drivers may attempt to power on by searching to ascertain every components, display momentarily the possible conditions to attain power shut down due to incompatibilities. Second, usually computers have component devices that operate differently. For example, similar computer may have dissimilar capacities of graphic cards where smaller computers graphic card were extracted together with the motherboard to be installed on a larger computer may not provide enough graphics capacity to display every details. Usually, the graphic card contributes to wards color resolution appearances on the computer. Compatible changes of motherboards only shy of graphics would display picture quality least achieving user visual effects. Usually advisable to change from new versions to older versions to attain update effects rather than change from older versions to new versions computer that would hardly display at power on. Third, the components that are changeable on the computers motherboard to least cause dilemmas includes entities like storage drives that may require reinstalling the operating systems as new ones are empty in content. Also, video cards, graphic cards, sound cards, expansion devices are those that add to feature improvements on the computer to attain experience. Once changing improvement devices within the motherboard, it is advisable to acquire the recent compatible to the entire computers brand model features to attain an improved experience also known as system updates or upgrades. At which point the computer should have provided in the momentary display a diagnosis observation from where adjustments to become functional is achievable. First attempting to maintain the entire motherboard changes by fixing the issues that are causing malfunctions is achievable. A hard disk drive may require erasure to capture a new system that is compatible with the entire computers components. Usually, hard storage drives are capable of causing to become volatile to allow for new operating systems software to be installed taking effect. In the situation of being unable to erase a preexisting disk, acquiring a new disk is plausible. New disk storage allows installing a new system of choice however require the entire software program. Once acquiring new disk with new software programs the computer mother board takes new effects altogether. Ascertain the functionalities of the prior existing components of the computer are necessary to acquire new disk storage and installation program software. Usually acquire a disks with vast entities to spaces to capture several new programs of operating systems, new user productivity software's and extra spaces for improvemts conditions as the computer exists. While at retail, ascertain to acquire each component parts with intent to building a whole device. The means of last resort is ascertaining the entire resources required to restore the old computer in costs to component parts, retails resources gathering if any available, inconvenience to make possible building another computer, costs of installations, technical guarantees to restore another device least recognizes as the manufacturers default. The ultimate means is discarding the old device as depleted of productivity to acquire new computer altogether. Computer resource components usually are generational where attempting to a build an old device with new parts makes the whole process redundant. The computer manufacture is most achievable entity to resort.
Feb 07, 2011 | Dell STUDIO 1735 Motherboard - H274K
My motherboard (p4m800pro-m v2) burned out and it seems the motherboard has been discontinued. It is absolutely impossible to find. Is there a recommended replacement or upgrade available?
I would suggest you buy a new board which will support your existing CPU and RAM, that way you will save $ on those items. Just do some shopping at FRYS.COM or TIGERDIRECT.COM
Getting it to work with your existing windows installation may be the challenge.
I would boot up on the windows cd, go through the installation till it says looking for existing windows... Then choose repair existing windows installation. This way it will install the initial drivers for the new chipset and video.
Feb 02, 2011 | EliteGroup P4M800PRO-M V2.0 Motherboard
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Sep 20, 2010 | Gateway Essential 400 PC Desktop
Would like to replace motherboard on old HP Pavilion 7940 but have no idea what boards will work. This is just for fun would be great if could be an upgrade. Don't want to spend fortune.
the motherboard is the heart or core of the computer. if you change it you will be forced to change it fot the same model (no upgadre exist, well a new computer will be a upgrade).
so if yoy take of the moder board you will be left with the other componenst like; the dvd reader, ram memory, procesor, modem, cables, and whatever you computer had.
so even if yoy manage to get an android motherboard (is a moderboard that is made to put diferent brand of components in it) and put the components that were left of the pavilion, you will get the same performance as your old pavilion.
if you whant to increase the performance of that hp pavillion 7940. look for upgrades for the moder board of that computer. like a better memory module. or a better video card for better graphics. i dont think that the processor can be changed in some models they are fixed to the moder board or the mother board will not support any other kind of processor.
Jul 30, 2010 | Computers & Internet
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ... > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP,
UserBenchmark: MSI G33M (MS-7357) Compatible Builds Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Upgrading motherboard
Dual graphic cards aka SLI require a SLI Power Supply. This is a good option if you want to start building a new system. Another option is just to get the new Nvidia 280 graphic card. Check out for a killer article on the latest graphic cards.
Jul 13, 2008 | Medion M3 Composer 5100 PC Desktop
DDR 333 memory is DDR PC2700, I believe. It might be hard to find a new MB that will work with that. You'll probably have to buy new memory. You'll also need a new CPU fan, unless you know the Socket type of your existing MB. But you should replace the fan anyway on a new CPU/MB install. You should buy as much memory as you can afford.
Try looking HERE and see if anything is in your price range.
Hope that helps...
Apr 25, 2008 | ASUS P4S800-MX Motherboard
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
