Question about Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool 465 Gas Stove conversion from propane to gas?
A friend got a slightly used stove that was set up for propane. On natural gas the burner barely lights just by the pilot light. Where are the orifices/items associated with the kit or do I just adjust something??
It is a Whirlpool Super Capacity 465
how do you get to the regulator or the orifice's? I don't want to break any thing and it seems hard to raise the cook top!
  • Anonymous Mar 22, 2009
    I have a like new whirlpool sf315 range got the new spuds for lp but can't get to top up, help.
  • 3 Answers
I HAVE A NATURAL GAS RANGE AND OT APPEARS TO HAVE ED-F3- ON IT AND IT IS LOCKED HOW DO I OPEN IT
Posted on Feb 23, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
Do not use the stove until its properly converted back to natural gas. It's a serious carbon monoxide hazard.
Most ppl throw the orifices away, sometimes they are stored under the stovetop in the back, or behind it. The original natural gas orifices are the only parts you need. All orifices are labeled by a tiny stamp on the side. It will state the size and type, example: 10 LP.....meaning number 10 size and propane.
A nature gas should be labeled something like 12 NG.
Call a local parts dealer or order online the NG orifices for you model number.
I assume you do not have the setup instrctions that come new with the unit. Heres what you need to do:
1) Change the orifies to NG (the bigger the burner the higher the size number) so if you have two #10 size, one #12 and one #14...then common sence will tell you where they go.
2) convert the regulator. This is the part to which the inlet connects. Remove the vent cap,(a plastic cap, you'll see it) unscrew and flip the insert over and reinsert it (You'll usually see 'NAT' on one side and 'LP' on the other). Reinstall the cap, and that's done. The word NAT should be facing you where you can read it.
3) Then, find the brass orifice that supplies the bake burner (usually under the range, behind the drawer), and if included, the broil burner (usually inside the oven). These are adjustable, and, like adjustable top burners, are simply 'snugged' down clockwise with a 1/2 inch wrench. You need to screw these back up for natural Gas.
You know when the oven is correct, you should get a nice blue flame on top as well as in the oven. Flames with yellow tips are wrong!
Posted on Oct 28, 2008
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
How do I convert a Whirlpool super capacity 465 cook stove from natural gas to LP propane?
you have to change the little nozzles at each burner to smaller ones and then switch the plastic orfice around in the gas regulator thats on the stove where the gas hooks up.whirlpool should offer the kit to convert this stove.this must be done to insure it work properly.
Oct 28, 2009 | Whirlpool RF378LXKS Electric Kitchen Range
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
Whirlpool regulator
Hello arizonascrat
Welcome
You said You just bought a whirlpool gas stove, but it is set up for natural gas and you need it to be for propane gas. How do you do this? Do you have to purchase anything, if so where? Whirlpool GR 465 LXLS THANKS, in advance, Norma
They make an LP conversion kit What you are asking and it should cost only about $20 dollars.
One Model # is, 8576846A
Now some places have it using different numbers!
Make sure to ask if this is for you range. I believe on kit fits all Whirlpool Gas products.
We have sponsors here on fixya that you can order this from.
One I believe is the repair clinic.
Thank You for using Fixya.
Huuum
Please remember to leave me a solved rating!
Oct 12, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Accubake SF362LXTS Kitchen Range Logo
720 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
