Question about Dell Inspiron 6000 Notebook
Laptop won't boot.
On start, I get "Primary hard disk drive 0 not found. No boot device available. No bootable devices." Any ideas
Hi, I don't have a solution but I get this error, but it does it without me knowing, my laptop can be on for alittle while and then I can walk away from it for a few seconds to go to the kitchen and have a small glass of water and then come back only to find that the laptop somehow restarted itself and has that error up on the screen so I turn the laptop off for atleast 2 hours, and then I turn it on and it reads it again but I already know that it's slowly starting to go and I'm backing up as much as possible before replacing the hard-drive.
Posted on Jun 28, 2009
  • 73 Answers
If it used to start up OK, then the hard drive is probably broken and needs to be replaced.
If you're adding a new hard drive, it may need to be partitioned and formatted. Insert your Windows CD, and start up off that, and run the Windows setup. It will format and partition the drive for you.
Posted on Feb 08, 2009
    President:
  • 2,110 Answers
This error arises due to hard disk failure...plz check Hard disk is detected in BIOS or not...
4 Suggested Answers
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
  • 13433 Answers
SOURCE: No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
Posted on May 22, 2009
  • 34 Answers
SOURCE: primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Posted on Jul 18, 2009
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My laptop has trouble booting. it takes me up to
Sounds like a failing hard drive. Try replacing with a different HD (preferably a known working one that doens't have important data on it) and try installing the OS to it.
-=/ Daft Tech /=-
Oct 22, 2009 | Dell Computers & Internet
May 22, 2009 | Dell Latitude C600 Notebook
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
[Repost] Can't start windows
Ok i had the same problem today:
firstly check to see if the HDD is on its own IDE channel (ie. not sharing with another IDE device such as a CD-Rom or DVD drive)
if yes disconnect the Optical drive or other device on the IDE channel and boot and if it still isn't working change the IDE interface used if this still doesnt fix the problem.
Boot with the Windows Install CD and see if you can do a system repair / chkdsk , if the HDD is still not detected you possibly have a problem with your motherboard / HDD
to determine if its the hard drive if you have another HDD spare which you can try boot off give that ago and if it succeeds your other hard drive is failing time to get a new hard disk.
If you still have no success time to look for a new computer or get it changed under warranty if you still have it ?
Aug 18, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Can't start windows
The issue you are having is that your computer is not seeing the harddrive or the boot drive. This could be a simple fix from the bios by telling the computer what device it needs to boot from which in this case is your hard drive.
You say that it did work and it was working how long ago was that? It also could be more serious in which you hard drive has crashed or exceeded its MTBF (which means "mean time before failure").
Aug 17, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
Apr 27, 2008 | Dell Latitude C640 Notebook
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell Inspiron 6000 Notebook Logo
181 people viewed this question
Alun Cox
