Question about Shredder SH2006PB
Ran hesitantly for 4 or 5 shreds Then would not shut off.
I remove all staples before shredding. I missed one. Did not run hesitantly right away but later was reluctant to shred. Then it would not shut off no matter what position the switch was in.
I have a Techko Model SH2006PB.
  • 2,559 Answers
The feed switch located in the feed slot is jammed,you may be able to clear it with a small knife or screw driver.(just make sure to unplug the unit first)
Please rate this a fixya with the blue button below.
Posted on Feb 09, 2009
There is an optical sensor that needs to be cleaned. It is usually at the middle of the slot where you put paper to be shredded. Use canned air to blow out both holes (one on each side of the slot).
Hope this helps.
Sep 22, 2016 | Staples Office Equipment & Supplies
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
Mailmate by staples shredder won't shred
drive is seized-remove power cord- open cover rotate cutting drum slowly using motor drive gears - look for debris/gear teeth missing
Mar 02, 2014 | Office Equipment & Supplies
Staples titanium shredder
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Jan 08, 2014 | Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
I have a corporate express shredder (CEBM6). Half way through a shredding job the overheat light came on and now the shredder wont go forward or back. I've shut it off to let it "cool" - how...
The unit requires a complete cleaning and oiling , there is paper shreds jammed at the sides.
Staples or Grand and Toy should have the shredder oil.
Jun 14, 2011 | Corporate Express CEBM6 Shredder
After shredding a piece of paper the machine wont shut off it keeps running
Please check to make sure the paper sensor is not blocked in some way.
This usually happens if there is any sticky tape on the paper or envelope shredded.
Apr 01, 2011 | Staples Office Equipment & Supplies
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Shredder SH2006PB Logo
214 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
