Question about Nikon Photography
Instruction manual for settings on a Nikon F2?
I need an instruction manual for a Nikon F2.
How do I set the ISO/ film speed?
Is the apperture set by the lens ring?
Is the shutter speed the dial on the top?
What are the other buttons on the front for?
What are the T and L for either side of the shutter release button?
Can anyone help?
    Scholar:
  • 48 Answers
Set the film speed with the dial on top of the Photomic unit. Lift the chrome ring and turn so that the film speed is next to the little red arrow.
Yes, the aperture is set by the lens ring. And if you have one of the older finders which uses the prong meter connection, whenever you mount a lens you must turn the aperture ring all the way to the highest number, then back to the lowest number. For old-timers, this is known as the "Nikon twist". It tells the meter system what the widest aperture of the lens is so that it can measure light properly at full aperture.
Yes, the shutter speed is set by the dial on top. The Photomic meter sits on top of it, so you read the shutter speed from the scale on the side of the Photomic dial by the mark on the back.
The other buttons on the front are the lens release button (left side as you hold the camera), DOF preview (button just under shutter release), mirror lock-up (lever ring around DOF button) and self-timer (long lever at bottom).
The T-L ring serves to protect the shutter release from accidental push. If you lift the ring and turn the mark to L, the shutter release is Locked. If you lift and turn to T, it prepares the shutter for Time operation, where the shutter remains open when released without holding the button down as you do at the B speed setting.
Finally, the most help: you can download the manual for free (donation requested, and worth it) at http://www.butkus.org/chinon/nikon/nikon_f2_photomic/nikon_f2_photomic.htm
Posted on Feb 09, 2009
ISO DX ERR
What speed film? Does the roll have the DX markings (the black-and-silver rectangles)? If it doesn't, what happens if you set the film speed manually?
Mar 22, 2013 | Nikon N6006 35mm SLR Camera
How to set asa on nikon 5005
If the film has the DX coding on the can then the camera automatically sets the film speed. If the can is not coded then the camera automatically sets the ASA/ISO to 100, and there is no way to override this.
If you need a manual, you may download one here.
Mar 05, 2012 | Photography
Ok, so I got the instructions on using my Polaroid 340 camera. I understand all the instructions, have loaded the film correctly but am uncertain on settings for the film speed. I am using 100 speed film ...
Try replacing the battery. It sounds like the shutter is not opening at all. Setting the speed to 150 will not make it better, rather the reverse, but you still should get an image.
Nov 29, 2010 | Cameras
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
Shutter stays open
According to what you say, it seems that you selected B (Bulb) as shutter speed (and MANUAL mode).
First, check whether you are on MANUAL mode ("M"); then, check your shutter speed. If it's really in "bulb" mode, all you have to do is dialing the speed button down to figures that match your subject's light conditions and your other preferences involved in the exposure (ISO, lens apperture).
Feb 07, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Nikon NEWBIE
put simply the ISO number is how sensitive the film is to light, the higher the number the more sensitive the film. The ISO on the camera sets the exposure system to give the proper exposure for that film (the f/n80 usually sets the ISO automaticly). Also the higher the ISO the more grainy the picture, I would recommend using ISO 200 film for the pictures you describe. I would set the camera to the P setting it is a good all-around setting.
Nov 18, 2008 | Nikon F80 35mm SLR Camera
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
Film speed override?
Press and hold the ISO button on the top left and rotate the command dial on the right until the film speed appears on the display. Release the ISO button and the speed is set.
In case your instructor hasn't told you, IR light is just below visible light on the spectrum and has a longer wavelength. Therefore, IR light will focus behind the film plane for a given setting. I.e., if you preset the lens to focus at 10 feet, the IR light will focus at a shorter distance. Unless your lens has a distance mark for IR, I would limit my shooting to longer distances and smaller f-stops to use the depth-of -field to compensate. When you are in focus for IR, the image in your viewfinder will be out of focus. The closer you are to the subject, the more out of focus the image will appear at the correct focus setting.
Sep 07, 2008 | Nikon N6006 35mm SLR Camera
Film speed setting
film speed is normally automatically set by small contacts that touch the checker pattern on the film cassette. It is most likely that these are not contacting properly, or there is a fault with the circuit that controls these.
Jun 10, 2007 | Nikon F60 35mm SLR Camera
Photography Logo
194 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
