Question about Pioneer VSX-05
No sound out of Front Left/Right Speakers on 5:1 setup
Have switched speaker connections around and run setup and Lev tone test(s) Only ONCE out of multiple setups did the speakers even show up and have a tone. Have switched front/rear setups too. Brought in another speaker and it tested with a tone - but only once.
I'm thinking that the front speaker setup in receiver is fried or at best near fried with the limited # of successful tone test (2).
Any other tests to try and verify?
I have the same problem with my sony receiver. seems like the fronts and sub have no output after sitting idle for about one and a half years. center and rears are ok. any help folks?
Posted on Feb 09, 2009
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
We have had this system for more than 6months. We turned it on the other day to discover no sound output. Nothing through blueray, iPod, cd or even TV. We have 2 x hdmi cables and 1 x optical cable. Any...
It can be either problem with the receiver itself, cables or your speakers. You can try different combinations to narrow down the issue.
1) Also the radio does not work?
2) Try to run the Test tone to the speakers (Setup / Speaker setup / Manual setup / Test tone). If you hear the tone, then the issue is configuration problem with your inputs.
3) If possible, try to connect headphones to the receiver. If that works, it can be issue with cables/speakers or their setup.
4) Try to run the Automatic Speaker setup with YPAO microphone. It will eventually fail, but will provide you error code, which you can lookup in the manual for different reasons.
5) Try disconnecting all the cables and reconnecting them again, possible trying left speaker with right cable and right speaker with left cable.
Jan 12, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
6140 will not complete the AUTO SETUP
If you would like to bypass the auto setup which is apparently the root cause, use a test cd/dvd for your test tones. The auto setup while convenient is not the optimal way to get the best result as the test tones it uses are bandwidth limited pink noise. If you would like to use the auto calibrate however, it's likely needing repair to do so.
Dec 23, 2009 | Yamaha HTR-6140 Receiver
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
288 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
