Question about Dometic Rooftop RV Air Conditioner
Furnace won't turn on, off, with or without remote
My suburban furnace SF30 and Duotherm AC use a dometic remote. This cold morning it stopped working. Batteries are good. Won't turn on, off from the remote or from the ceiling mounted control. Help!!!
  • barbrogers Feb 08, 2009
    You won't believe... First we shorted the wires to the thermostat and the fan came on. That showed that the thermostat was the problem. Then we asked another camper with our model if we could try our remote on their furnace. It worked. Then the other camper said he had problems earlier and the solution was: unplug all electric including the battery, wait a few minutes, plug in again. Somehow the process reset the circuit board. IT WORKED!!!
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Posted on Feb 09, 2009
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
How do i bypass the furnace and still use the duotherm 57915.531
Do you have the digital thermostat? You can tell the thermostat you have no furnace. You should be able to disconnect power at the furnace, but the 12v power for the circuit board is provided by the furnace circuit on some systems so make sure you disconnect the wire going to the furnace and leave the wire feeding the circuit board.
Oct 06, 2014 | Coleman Dometic Duotherm Rv Air...
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
the ignition switsh it wet or spark plug defective u need a replacemet in this case!
Feb 27, 2009 | Dometic Rooftop RV Air Conditioner
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
856 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
