Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Will not drain and move to next cycle/Lt700xv
Machine washes, then will not drain and move to the next cycle.
Machine washes but will not drain then moves to the next cycle, What do I do?
Posted on Feb 09, 2009
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
The water will not drain out
Check on tips for finding if you have a blockage, or pump fault.The door will open if you can remove the water.I have tip posted. for checking this problem
Mar 05, 2010 | Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Machine fills rinses and stops before drain and spin
Sounds like your timer is not moving the gears to the next cycle.
May 18, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washing Machine
the problem is the pumping out of the water it be something caught in the pump or the pump is faulty remove it check it out. Close Ireland,bye bye
Nov 21, 2007 | Washing Machines
Series 90 machine does not drain before spin cycle
Arts, you lost the neutral drain in the gearcase. This should be under warranty for 5 years. Call Sears and see what they can do for you. Attached is a pic of the neutral drain assy. Catriver..post back.
Oct 17, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
