Question about DeLonghi 6707E Oil Filled Radiator Heater
I need to reset my Delonghi radiator. it overheated
I made the awful mistake of tossing my house coat over my Delonghi oil filled radiator heater. It turned itself off and will not go back on until it is reset. I don't live anywhere near a service center. Does anyone know how to reset it?
Unscrew the four screws holding the front faceplate on (two are on the bottom of the radiator). From the bottom end gently pry up the faceplate, it will stay attached at the top end near the temperature selector. Look inside and you will see a black bridge like piece of metal with a plastic and metal thing stuck to it's center with two wires leading into it. It's basically a connection that melts when high temperatures are reached, therefore it must be replaced (pictured). You can bypass this by prying the metal bridge out, removing the wires leads from the switch and connecting them using a wire nut. BE AWARE THAT THIS WILL OVERRIDE THE HIGH TEMPERATURE SHUT OFF MECHANISM, so don't use it for drying off your coat again.I need to reset my Delonghi radiator.  it overheat - _361.jpg
Posted on Dec 29, 2010
As I have found, the thermal switch, in my De Longhi Bambino heater can be re-set manually so that there is no need to buy a replacement. The button is in the back between the two electrical connectors.
To get at it on my Bambino, which may be similar on De Longhi oil filled heaters, I had to unscrew the foot on the controls side, then two more screws in the metal bit behind and then unhitch the metal bit from a socket near the top.
Posted on Feb 06, 2018
Same problem. any solutions?
Posted on Jan 03, 2010
Do i need to add oil
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
Jan 12, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Actual output on settings
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Oil radiating heater won't heat
It could be many things, but the first thing to check is if the heating element is good. You'll have to (carefully) disassemble the unit.
Another thing that is possible, depending on the unit, is that the fuse is blown on the internal circuitry of the oil heater. A third possibility is that the thermostat is defective or has a short circuit.
If you are not comfortable monkeying around in the guts of the unit, call the company and ask what service options are available.
Mar 18, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
DeLonghi 6707E Oil Filled Radiator Heater Logo
2,349 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
