Question about Toshiba Satellite A135-S2386 Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hey,
I have an hp pavilion dv6000 and suddenly its dvd-rw driver (which is optiarc DVD RW AD-7561A ATA) decided not to work. when I put a dvd and click on Drive E it ejects the disc and says "Please insert a disc in drive E" and even doesn't try to read it. when it's a CD it tries to read it for a while and considers the disc as a blank 702 mb writable cd and asks write method.
my os is vista.. is it a pysical problem or something about drivers etc.? HELP HELP
my HP paviliondv4 1123us NTBK PC does not want to load my dvds to view them.....it does not aknowledge them as inserted i`ve tried either before or after turning the quickplay on....HELP
  • Anonymous Mar 21, 2009
    i have a problem like that,
    it doesn't show on "my computer", it only shows on device manager, says that device can't start (error 10)
    we got it fixed once and the help people had to change the registry to make it work, and now it is out of warranty :(
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
Posted on May 29, 2009
  • 1 more comment
  • gary smith May 29, 2009
    If you need to know where to navigate in the registry, i can post it...
  • cscheck857 Dec 06, 2010
    I would like to know what keys need removed. I am having this same issue now.
  • gary smith Dec 06, 2010
    Follow this link and your problem should be solved.
    http://support.microsoft.com/kb/929461/e...
    Genius:
  • Toshiba Master
  • 1,102 Answers
Right click dvd drive
then properties
check in autoplay
hardware
and recording make sure all your settings are proper then restart
your drive may just need cleaned dust can cause this to happen
after exhausting these suggestions if it still does not work then device manager update driver again restart
if still poblem then devicemanager uninstall driver restart allow system to reinstall
was vista your original operating system whaen did the problem begin
please let me know and please rate me
Posted on Feb 08, 2009
Optiarc dvd rw ad-7561a ata device unplugged
Check BIOS for Optical drive. Press F key noted on boot screen to enter. If it's not noted there, you need to check physical connections. Might just need to be re-seated with power disconnected. Re-check BIOS and make sure to save before exiting.
If it is noted in BIOS and Windows still fails to see the drive. Run a thorough virus scan, then boot into Safe Mode by pressing F8 during startup. Go to Device Manager, and select Show Hidden devices under the View tab. Delete all drives and reboot. Windows should say new hardware found and install.
This should take care of the problem if there is nothing wrong with the drive. Replace or seek professional support is not, and good luck
Dec 11, 2012 | Computers & Internet
My optical device needs drivers
Optical drives don't need drivers, they all use the same generic driver that comes with Windows.
Jun 12, 2010 | HP Computers & Internet
Hp dvd rw AD-7561S ATA, its only reading dvds.t
Guess your lens is bad... Clean it properly or better still, buy an external cd rom.
Feb 14, 2010 | HP Pavilion Dv3-1075us Notebook
The driver is not detected by laptop
Is your dvd drive capable of doing light scribe?: If not, then the driver won't make it work. It takes a special drive to use lightscribe, and it should be part of your CD/DVD burner software. I highly recommend Nero software as the best, more reliable and easiest to use. Also, it the brand that usually comes with New CD and DVD drives.
Oct 09, 2009 | eMachines T5274 Desktop PC
Optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
The Optiarc DVD RW AD-7561A ATA won't work on hp pav dv6000
Windows uses generic simple drivers for any optical drives. Try deleting the drive from device manager and reboot. You do not need to download anything special for windows to operate a drive. If you cannot access the drive then it may be damaged or a hardware fault.
Jan 25, 2009 | Computers & Internet
Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
http://cr.am/framed.php?url=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2Fdocument%3Fdocname%3Dc00817052%26lc%3Den%26cc%3Dus%26dlc%3Den%26product%3D3752864%26os%3D2093%26lang%3Den&ref=driverguide
Go to this incredibly long link (sorry about that) and look though the solutions there, it says it is for hp and sony computers but it has the same principal for all dvd/cd drives
I hope this helps
Dec 19, 2008 | eMachines T5274 Desktop PC
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
http://support.microsoft.com/kb/314060
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
http://support.microsoft.com/kb/929461/en-us
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite A135-S2386 Notebook Logo
5,070 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
