Question about Sony Playstation 3 (PS3) Console
A humming noise coming from tv when cable and ps3 are hooked up
When i switch over the input from cable/antenna to av1 and then turn on the ps3 i get a humming noise, if i disconnect the cable/antenna it stops, or if i wiggle the av in back of the ps3 the humming, changes tone, and also there was a few times where i went to plug the power cable to the back of the ps3 and got zapped, the ps3 is only 6 months old, and the tv is a brand new 47 inch philips lcd, someone please help
  • Anonymous Mar 06, 2009
    same hum
I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
Posted on Jun 18, 2009
  • 52 Answers
Change your power cable and see if that helps. You are getting a leak somewhere. If that doesn't work replace your AV cables and it should fix your problem.
-Captain Jake
Posted on Feb 11, 2009
How can I connect my ps3 to a konka tv? Is there an specific channel that I have to tune? I tried AV1 Av1 and it doesn't work?
if the output wire from the ps3 is an rca type, you can hooked up only to the component input like the av1, av2 or av3.
Oct 27, 2012 | Televison & Video
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Tv was on an antenna. Now its hooked directly to cable. Cant get a picture. It keeps saying no signal. Any ideas what to do?
press the button that changes the signal input i.e. AV1,AV2.......until you find the input source for your cable. consult your user manual. Good luck.
Aug 12, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My Panasonic Viera TX-L37U10B won't display my Sky+ picture when it is turned on. We have to opt for ''AV1'' every time the TV is turned on!!! Why won't it show my current Sky channel on boot up??
Because the default input is the antenna, not one of the external inputs. If you want it to be picked up at start remove all antenna cables and start the Sky receiver before starting the tv - this is because only when there are no signals from the antenna the tv starts to look at the AV inputs.
Jan 12, 2010 | Televison & Video
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Sound but no picture on PS3 using AV3/4
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
A slight feedback noise from speakers while playing playstation 3
probably your wires. any time speakers hum something is not connected properly or there is interference from another gadget nearby. Invest in some better wires and your problem should go away
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Sony Playstation 3 (PS3) Console Logo
550 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
