Question about Linksys WRT160N Wireless Router
Microsoft MN-710 usb driver can't see my linksys WRT170N
I set up my wireless router through my mac laptop, and it connects fine through the router. My desktop has the Microsoft MN-710 usb driver verson 1.0.8.0, can read all the surrounding routers in my complex, but can't pick up mine. I tried updating the firmware, which didn't work. I reset the security protocols, and made sure broadband was enabled. I set the settings on mixed, g only, n only, etc. and that didn't work! I tried unplugging the router and modem, etc etc, and it didn't work. Any ideas?
  • Ved Pradhan May 11, 2010
    hmmm...
    did u try changing the channel number? if not then toggle between the channels 1,3,6,9 and 11 and see if it works and you can also go ahead and update the drivers....
    check it this works
    vedhick
  • 46 Answers
Software package lacks WPA patch for Windows XP for the MN-710.
Just a guess but I think your PC is unable to authenticate the AES encryption you probably have on your wifi router.
I would say go out and buy a new wifi dongle for your PC that can handle the speed of your new router anyway.
Posted on Feb 10, 2009
My laptop is not picking up my wireless
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 06, 2010 | Microsoft Broadband Networking MN-500...
How to set up router with a lap top
well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Wireless router is working fine to connect to the
Did you install anything new on the computer you are working on? I suggest you to check the version of your printer driver software according to the driver CD you had and reinstall the compatible version of the driver on your computer with a USB cable connected after totally remove the drivers and settings for that printer on your computer now.
Jul 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
When logged into wireless router the computer can't get internet
I have ever experience the same problem you are having .
I have re-position my pc location. Normally when we are over long distances we got this error.From my experience i would suggest you to try to align your pc and router in such a way that there is less walls and obstruction.
hope this will help
Regards
uttam
Dec 14, 2009 | Microsoft Broadband Networking MN-500...
I had a earlier problem with my wireless network adapter in my laptop not fully installing. I bought a driver program and now I should have the most updated driver and the driver is working. my continuing...
To configure the wireless router and the laptop's wireless card, follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 17, 2009 | Linksys WRT160N Wireless Router
I have a linksys WRT54g router set up to a desktop. I have 3 laptops on wireless - 2 laptops connect to the network just fine - but the 3rd laptop connects with limited connectivity. What can I do to get...
double check that your router is not broadcasting in only G, make it reverse compatible. There is a chance that the other laptop may not be G compatible. Also check the security key and make sure it is correct. If your blocking connections by MAC address make sure the MAC of the non functioning computer is added. You may want to delete the current connection settings from the laptop and restart with a fresh wireless connection. I hope this helps. Good luck
Sep 25, 2009 | Linksys Wireless-G WRT54GS Router...
I have cable internet but it will not recognize MN 500 base station for internet
You need to perform MAC Address Cloning. Make sure the physical connection is fine. From modem to internet port of router, from pc to port 1 of the router as well. Now open the admin page of your router and look for MAC Address Clone settings. You have to enable it and click on Clone. Save the settings and power cycle your device for 1 minute.
Jun 26, 2009 | Microsoft Broadband Networking MN-500...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
Linksys WRT160N Wireless Router  Logo
428 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
