Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Change in bottom of the bucket
We don't always get the coins out of our kid's pockets and they seem to end up in the botom of the secondary bucket. The only way for this to happen is for the coins to float near the top and spill over into the secondary. The coins will make a scraping or grinding noise during the spin cycle. We've had Whirlpool out twice to remove the bucket and discard the coins but at $100+++ a visit I need to figure this out myself but can't seem to find disassembly instructions or a shcematic of the machine on line.
  • 6 more comments
  • lwhiteley Feb 09, 2009
    coins keep getting stuck in the secondary basket and I want know who to fix it myself.
  • jlynch012 Feb 09, 2009
    I have the same problem with change getting into the 2nd bucket. The change actually made its way to the pump and cracked it causing a minor flood in my basement. I have had the repair men out to my house twice for this problem. This has got to be a defect--how can change cause problems in this washer, but not in any other washer I have had?
  • mike-mcd Feb 09, 2009
    I have the same problem with my Whirlpool Cabrio HE WTW6400SW with change getting into the 2nd bucket. The change actually made its way to the pump and cracked the drain pump housing causing a minor flood. I replaced the entire drain pump assembly ($80) only to have new break one week into usage. Cracked housing is lightweight plastic and not sold separately, only as part of drain pump assembly. I have contacted Whirlpool but no response. Trying to figure out if any filter to block coins from entering drain pump assembly which appears to be crux of the problem. I have never expereinced this with any washers I have add before.
  • etnmk Apr 04, 2009
    Just replaced the Pump. Prior to it failng I had been removing the pump and coins. Got a little tired of removing the coins and left it go.
    Finally broke a hole in the pump housing flooded my laundry room.
    May have found a little easier way of removing the coins though. Remove the back cover. Remove the dischage hose clamp and hose only. You will get some water so have some towels available.
    Use a shop vac to **** out the remaining water and coins. Look in with a flashlite to be sure you got them all.
  • Anonymous May 16, 2009
    Just has a service guy out to replace the second pump in 2 months. Found change in both, which resulted in cracking the cheap plastic housing. I ordered the second pump on my own for $95, due to the fact that the appliance company will not honor the warranty anymore. They claim that loose change voids the warranty.. Needless to say I'm not happy!!!!
  • Anonymous May 21, 2009
    it doesnt seem to wash clothes correctly
  • nicholsonsir May 22, 2009
    I have the same problem, my Washer flooded my laundry room. The tech came out and said that it was not covered unless you have the extended warranty. I have the extended warranty and they still wont fix it. I believe this is unfair so I filed on Lowes in small claims court. the court date is coming up in a couple of weeks. Whirlpool customer service is a joke.
  • Whirlpool Master
  • 2,651 Answers
Ohter than preventing them fom going into machine, ther eis no way to stop them fom entering the outer basket'pump assy.. you can popo the top of the machine and tip it back, then by removing the plastic outer cover (covering the outer to inner tub) youll be alble to lift out the basket and retreive errent debris..
Posted on Feb 14, 2009
My mini camera 208c colors are messed up
Ahh, mushrooms are a wonderful thing.
Jul 09, 2016 | Cars & Trucks
Zasounussi problems
on all front loaders, the smell comes from not been used every day, #1, and water sit at the bottom of the drum, is always water in the system from the top of the drain hose to the pump, and they, the manufacture recommend that you use some chemical once per month to clean the unit.
this is what I do. get a bucket of water and bleach 3 water 1 part bleach, get a rug that you do not need any more. wet the rug and with your hand open the door and put the rug unter the rubber around the glass door, in other worth's, the rubber that connects the door to the drum bucket rinclos and water and other material stays there, building mildew, would be good to wear a globe, and clean the inside of these rubber real nice, go around several times to make sure you don't miss a spot., the cloth well come out black means it is loaded. then put the rest of the water and bleach in the machine, add 2 caps of bleach in the machine, fill it to hi and let it stay for 1 hour or more in the drum, then have a gentle cycle, these well clean the rest of the unit. one more thing, if you have members of the family that forget coins or papers in they pocket. may have to do more work to clean and drain the unit, just let me know I well help you.
Apr 14, 2014 | Washing Machines
No heat in car but blower works fine
your heater core might be clogged or have an air pocket in system for this, when engine is cool, take radiator, if you have a no spill funnel to use, then set it up and car and fill your no spill funnel and let it run to burp your system if you dont have one, then take cap off, place a bucket under.your radiator, start your car, let it run till warms up, watch your antifreeze if it starts to burp.and lower, then you had air pockets, it also.helps if you raise the front end of your car to a little if your heater core is clogged feel your heater core hoses, the top one should be hotter then.the other one, if not, back flush your heater core to do this, wait till your engine cools, take off both.heater core hoses then get about 6 feet of heater hose the same size, place about 4 feet of hose on the top heater core line and place a clamp, put this hose into.a.bucket, take the other two feet of hose and place on the bottom heater core line and clamp then take your garden hose and turn water on, into the bottom heater core hose, this will push all the antifreeze and junk out the top hose that goes into.the bucket do this till you have clean water coming out now if you also air compressor, after you have clean water, do the same thing with the air hose, but only use no more then.20psi of air, you dont want to screw the heater core up after you did the air, I.always run more water though it.again to make sure everything is out after you have done this, put the heater core hoses back on, and fill system, start your car, and do as I.said above to burp the system also check your radiator cap, I will always replace them if they.are more then 5 years old, the gasket goes bad, for every psi you lose in your system, you lose heat, I forgot how the math works, but it can be 10 degrees of heat lose do.a.back flush when your eng is cool
Dec 05, 2013 | 1999 Ford Taurus
I have a kenmore elite front load washer and have problems with it draining completely after washing a load, from what I'm reading this seems to be a common problem with these machines, is there a recall...
if it isnt draining completly theres a 90% chance it is simply blocked, its only a common problem cos people DON'T EMPTY THEIR POCKETS! (i see this quite often infact did this morning) chances r u eitha have a bobby pin jammed in the pump propellor or a 20 cent coin acting as a butterfly valve in the tubing jus before the drain pump 20 cent coins fit perfectly through the pipe work but stop on the drain pump intake and can open and close letting water out sometimes then closing on others, if your any good with pulling stuff apart just remove the rubber piping coming off the bottom of the tub normally just a ring clamp and check for blockages and also remove drain hose and look in the hole and stick a screw driver in the hole and try turn the propellor round
Jan 24, 2011 | Kenmore Elite 45986 Front Load Washer
Machine won't spin
The most common reason for this is the pump is jammed - usually with a coin or sock or something.
The pump may be accessible from the front bottom of the machine - look for a little box open it - and you will access the coin - you can clear it and try again - remember to put the coin trap back together again.
Alternatively, if no coin trap is present you will have to tip the machine back - and look for the pump usually it has two black hoses going into it and it is situated near the bottom of the machine - remember when removing the pipes water will come out - so - have a bucket close by to catch the water.
you may find what is jamming the pump there - if there is nothing the next likely culprit is the timer... try moving the programme dial on a little bit see if the spin starts - if you have a digital machine there will be no way to try the last fix.
But the pump is almost always the problem!
Good luck
Jan 07, 2011 | Washing Machines
I have a Kenmore Elite washing machine, and while washing a load of laundry, the washing machine stopped.
So you have water in the bottom at the end of a cycle. Clean out you drain pump's coin trap, and stop putting clothes into the washer without clearing the pockets.
Nov 19, 2010 | Kitchen Ranges
Why are there coins in my dryer lint trap?
when a person has coins in their pockets & forget to take them out,when the clothing is wash sometimes the coins don't get washed out,, but when you put the clothing in the dryer the tumbling will help the coins come out of the pockets that when they go to the dryer lint trap or bottom of dryer
Aug 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Is there a second filter
You have not posted a brand, however central vacs with an internal hanging `self cleaning ` filter seldom contain another filter with the exception of Eureka or Kenmore which may have a secondary optional paper filter installed. Check the bucket and the gasket first. Eureka and Kenmore made by Eureka are prone to a defective gasket which disintegrates with wear. The bucket should sit snug on any unit with no play.
To test for proper suction check at the vac intake itself. If the suction is strong here and weak elsewhere your problem will be either a clogged vac line, a leak in a pipe or an inlet door sagging open, last of all a clogged or partly clogged hose.
Check your hose by dropping a coin through the handle and shaking it down to the other end. If a coin makes it through your hose is clear.
You can test each inlet with a numbered tissue and your hose. Mark one for each inlet and check the tank to see what made it through. If any fail to make it through, go to that inlet with another vac and draw the blockage backwards out the inlet. Then retest
Also listen for a hiss at each inlet with the hose plugged in elsewhere. The hiss indicates a leak behind the inlet in the wall. Check for worn seals or misaligned o rings in the backing plate where the inlet connects.
Last of all inspect the pie for possible cracks from impact . If you listen closely you will hear an audible echo along the pipe path (even within the wall) if a connection has separated or a pipe is damaged.
Please post back with what you find or if you need more help.
Oct 13, 2009 | Vacuums
My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Starts out draining
What you are experiencing is what i have experienced for the past 6 something now before it gets worse.....
I have discovered that there should be a warning with the NEW FRONT LOAD washers, and that is....ALWAYS EMPTY out pockets of clothes. WIth the typical top load machines...its seems that the "stuff" we left in pockets, ended up in the bottom of the disc of the washing machine, and actually became a game with much money could i find after washing my husbands pants!...never able to go much further than that....but with the front load machines....whats left in the pockets, gets "eaten" by the machine , and the rubbery entrance in the front of the machine.....but items never to be seen, until you pay the a repair man to come out and tell you what you shouldn't do!
SO....sounds to me like, your drain hose is getting clogged, what you are experiencing is what i was experiencing for about 1 month before the machine just stopped working altogether! you can take off the front bottom cover (there are prob screws there) and then there should be a hose and sometimes a trap (where, if you are like us,...the repairman found about 5 dolloars worth of coins) that you can empty out...i guess depending on you type of machine....mine was a GE)
Feb 26, 2008 | GE WSXH208A Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
623 people viewed this question
Dan Webster
Dan Webster
Sal De
