Question about HP iPAQ H2200 Pocket PC
I need desktop software for HP iPAQ
I was given a hp iPAQ pocket PC but no software where can I download onto PC for free
  • Anonymous May 12, 2009
    HP iPAQ Pocket PC Companion CD
    President:
  • 2,110 Answers
I am trying to hook up my hp ipaq model h1910 to my emachine D6419 and it says to hook it up to Com 3 port on the back of my computer. How can I find out where that is on the back of my emachine? I lost...
Connect to a Computer
You can wirelessly connect to your personal computer using an infrared connection.
You can physically connect your iPAQ Pocket PC to your personal computer using Microsoft ActiveSync and a USB cable.
You must have Microsoft Outlook to operate your iPAQ Pocket PC using Microsoft ActiveSync on your computer. If you do not have Outlook, install the Microsoft Outlook software from the HP iPAQ Pocket PC Companion CD.
Microsoft Outlook Express will not work with the iPAQ Pocket PC and ActiveSync.
What book/manual are you talking about?
emachine D6419 can be found at;
http://global-download.gateway.com/GDFiles/Document/User%20Manual/User%20Manual_eMachines_1.0_A_A.zip?acerid=633933437244339685&Step1=DESKTOP&Step2=D SERIES&Step3=D6419&OS=ALL&LC=en&BC=EMACHINES&SC=PA_6E
hp iPAQ Pocket PC h1910 - Reference Guide at;
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002238.pdf.
Good luck and post back.
Jun 03, 2011 | Computers & Internet
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
No opperator instructions
Hey,
all the documents for it are available at this hp site
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=425745&
I think you will find all you need there.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | HP iPAQ H1945 Pocket PC
Plz tell me solution
U can download softwares from
http://www.getjar.com/mobile-all-applications-for-hp-ipaq-rx1950/
and games from
http://www.brothersoft.com/mobile/phone/hp/hp_ipaq_rx1950/games/
Dec 09, 2008 | HP iPAQ rx1950 Pocket PC
Hp ipaq pocket pc built in tom tom
You can download the manual from the link below: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?&lang=en&cc=us&contentType=SupportManual&docIndexId=179166&prodTypeId=215348&prodSeriesId=322916&lang=en&cc=us You can download the software from the link below: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=306698&taskId=135&prodTypeId=215348&prodSeriesId=322916&lang=en&cc=us If the Windows operating system has been removed you will need to purchase another copy of Microsoft Windows for Pocket PC 2003 or check any CD's that came with the device. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 18, 2007 | HP iPAQ H5555 Pocket PC
Hp pda ipaq rz1710 doesn't know to used
Download the manual off the HP site. It's FREE
May 12, 2007 | HP iPAQ RZ1710 Pocket PC
HP iPAQ H2200 Pocket PC Logo
925 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
