Question about Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range
I need direction on how to start the clean cycle on my jenn air
Jenn air jds 9860 a oven
  • 2 more comments
  • mikenlynette Feb 08, 2009
    I dont see any thing marked Auto Set on my dislay panel... does Auto Set refer to the display panel itself?
  • Anonymous Apr 06, 2009
    I need directions to start the self-cleaning function on my dual fuel range - Jenn-air JDS9860
  • grammy5 Apr 06, 2009
    I have the same problem but don't have auto set on my screenh.
  • Anonymous Mar 14, 2014
    jds 9860 oven does not work .Will heat up very slowly and only will heat to about 250 degrees
  • 360 Answers
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Posted on Feb 08, 2009
Broken inter glass for jen air jds 9860 saw
in layman's terms ,exactly what is it , where does it fit ,what does it do, what make and model and what parent equipment is it attached to
Nov 18, 2015 | Garden
How to clean my jen air built in oven
For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
I hope this helps.
Sep 11, 2011 | Jenn-Air JJW8530C Expressions Collection...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door will not unlock.
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Dec 13, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Open Questions:
Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range Logo
608 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
