Question about Microsoft Xbox 360 Console
Red Ring Around the Green Button
Will not work at all, the red ring flashes constantly
    President:
  • 2,559 Answers
The standard procedure of operation is to unplug all cables from the unit, reinsert them, and try booting the system again.
The ring is made up of 4 quadrants
Each quadrant on the set of flashing red lights indicates a different issue.
  1. If all of the lights but the first section are flashing, this means a general hardware failure has occurred. There is little to be done other than trying to unhook and reattach your cables. This problem is a sure sign a visit to the repair center is in your console’s future.
  2. If the problem is indicated in the second quadrant of the system, it is merely overheating. As too many hours of play will do that to a unit, the proposed cure here is to unplug the unit from the power supply, let it sit to cool down.
  3. A problem indicated in the third quadrant of the Xbox 360 ring of light is diagnosed as a hardware failure. Once again, try re-inserting all of your cords and cables, but this problem should definitely be dealt with by the repair center.
  4. If all four lights are flashing on the front of your console, this is perhaps the easiest problem to fix. This is an issue with the AV cable not being properly inserted into the back of the console. The cure? Just make sure the cord “clicks” once it has been inserted into the unit.
Please rate this a fixya.
Posted on Feb 08, 2009
  • 15,935 Answers
RED RING OF DEATH syndrome
CLICK HERE for information about getting it repaired by microsoft.
Basically it involves dis-assembling the unit and replacing the thermal paste between the CPU and Heatsink.
CLICK HERE for a TOWEL remedy.
THIS may work as an NO-TOWEL alternative.
Thank you for using FixYa - a FixYa rating is appreciated!!
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Three red lights flashing
If this is your Xbox 360 console you are referring to, then you need a repair. If you are under your 3 year warranty from MS go to www.xbox.com/support to fill out a repair request, otherwise look for someone in your area that has experience repairing the Red Ring of Death.
Jan 03, 2010 | Microsoft Xbox Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
My xbox 360 has the green ring and it turns red and shuts me off the game what is wrong .
that is called the red ring of death which is basically the processors overheating, you can try purchasing an intercooler unit which connects to the back of the console and you connect your power supply to it that way you'll have a constant fan cooling your machine you can get one from game stop, walmart etc. for about $20 if the red ring stays on after that you would have to send in the console for repair microsoft generally charges around $140 360 pros charge about $90 and provide a 90 day warranty you can contact them at 800 618 7215 for more info. Hope this helps
Aug 05, 2009 | Microsoft Xbox 360 Console
Xbox red green flashing lights
r they all red or only certain ones the most common thing to check first are the av cables/hdmi cable from the xbox to the tv.. if they are loose on the xbox it will show the red ring in a sequence make sure their tight...if this does not fix it YOU HAVE THE RED RING OF DEATH its either overheated or you have a bad disk drive or something internal....you will need to call microsoft
Feb 23, 2009 | Video Game Consoles & Games
Red ring
speakers terminal maybe short circuit------connect it properly.
---ventilation holes are blocked----turn it off let it cool down and turn it on.
-------the unit is operating in continuous high power condition---turn it off-----and let it to cool down.-------turn it on.
Aug 04, 2008 | Denon AVR-2307 Receiver
PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
Red ring
Bring it in for service. Usually that means a hardware issue. Hopefully you purchased extended warranty.
Jun 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
66 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
