Question about Epson Stylus Pro 9600 InkJet Printer
5 colors won't print
I have this printer that had not been used for a while. And the head is cloged. I want to remove the head and clean it with a cleaning solution. How can I remove the head from the printer? I already did the power cleaning on the printer but it will not unclodge the head.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 110 Answers
Generally catridge head cloged in case the printer is not in use for a long time,to clean the head chemical is available,alcohol based liquid is used to clean the head.
Posted on Feb 08, 2009
Epson pm235 printing problem one colour is mising .. cloged head... or cartridge assembly.
if saying color is missing will more than likely have to put in a new or partialy used cartridge for that color - you could try and run any options you may have for cleaning heads/nozzle checks and printing reports to see quality of the printing
Sep 04, 2013 | Epson PictureMate Office Equipment &...
PRINTER WON'T PRINT BLACK
The inkjets nozzles in the black print head maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 27, 2013 | Office Equipment & Supplies
Why won't my machine print in color
Jan 21, 2013 | Epson WorkForce 500 All-in-One Color...
Won't print in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 22, 2012 | Brother MFC 240C All-In-One InkJet Printer
Hp photosmart won't print in color
Sep 10, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
I am having trouble cleaning the heads on my epson 1400. I have done is numerous times, but still do not get a good pattern on the head check. Is there some solution I should squirt down into the head or...
Hi, what I do in these cases when the head printing doesn't work, is to send very complex or full color images to the printer, at the beginning it prints badly because the cloged head, but chances are that the clog dissapear after some time printing
Oct 04, 2010 | Epson Stylus 1400 InkJet Photo Printer
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Horizontal pink & blue lines across color pictures that I print.
In the past when I have seen this on my old printers, it is the color cartridge. Eithe the haed is cloged or it needs to be replaced. You could try to take the color cartridge and set the print head(copper colored end) on a damp towel for a little while and see if it will release the clog. (HP uses mostly water base inks and they dry out sometimes) Then wipe the head on a dry cloth. Reinstall and try again. You should also have software for HP to prime the head and clean it. Try that and if you still have problem, replace color cartridge.
Mar 03, 2009 | HP Officejet 9110 All-In-One InkJet...
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus Pro 9600 InkJet Printer Logo
844 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
