Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Error Code F5 E5
I have a Kitchaid oven - It has an error code of F5E5 - What does this mean?Tried the oven self clean function for the pre set 3.5 hours and got an F5-E5 error code after 30 minutes. Is it an electric grounding problem (which is what the guide says an F5 message is).
    President:
  • 2,110 Answers
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Posted on Feb 08, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most KitchenAid models, error code F5 E5 indicates that upon initiating the self-Clean, the oven was not able to reach the prescribed/expected temperature (normally within 45 minutes). Components to check would be the door closed sensor switch and/or door is locked sensor/switch.
In some instances, this could just be a glitch and a reset could be performed:
  • Press and hold any key for 1 minute to clear R failure code from memory.
  • F2 will appear.
  • Press CANCEL and observe for 1 minute to ensure operation is correct.
Good luck and thank you for using FixYa.
    Sergeant:
    Champion:
  • 289 Answers
Hi..this error code mean to over heating.It
means that your oven got overheated.so it
shows a error function.
check it out..
thank u..
  • Hariharanath V Feb 09, 2009
    hi..the best solution to this problem is by giving
    the owen for the service.
    try this out..
    thanks..
  • 15,935 Answers
Most problems in ovens arise after self cleaning option.
F5E5 - The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid ovens.
  • blueextc3221
    blueextc3221 Feb 08, 2009
    T.O.D. = Thermal Overload Device (sensor) has probably melted. Unfortunately there is a KNOWN dangerous problem with these ovens that KitchenAid has not recalled (as of yet)
    Master:
  • 848 Answers
The error code means Self clean temperature not satisfied after 30 minutes
. If door not latched:
Disconnect power from unit.
Check wires and connectors from control to latch switch, then from latch switch to control.
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
Tried to Auto Clean. Got error message: Door -F-5. It started to warm up but would not lock. What to do? Manual not to be found in house. Oven is about 13-15 years old. First problem I have had.
The F5 error code means that the control board has detected a error within itself and the control board needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button but if the error code returns the control board would indeed need to be replaced.
FYI when ordering the control board it also may be called the clock or eoc
GENE
Sep 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning stops after about 1 hr with error code F5E5
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Nov 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Code F5E5 after using self cleaning on KEBC107 Kitchenaid.
Hi, f5e5 stands for clean temperature not reached after 30 minutes. You should check your door gasket, hinges and you latch to make sure the door is sealing. You can take a piece of paper like a receipt and put it in the door and pull it out with the door closed to feel for resistance on the paper. If there is no resistance on the paper then the door is not sealing. you can try hitting the stop clear button for 3-6 seconds if that does not take the error code off then turn the breaker off for about 30 min.
  • F2 will appear.
Nov 10, 2010 | KitchenAid KEBC107 Electric Single Oven
Error Code F5 E5
Sep 05, 2008 | KitchenAid Architect Series KEBC107KSS...
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
2,646 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
