Question about IBM NetVista PC Desktop
Very slow boot on NetVista P4 1.6
I Install a new copy of XP on this box and it takes hours to boot. When it does everything works fine.
I went to prefetch in the registry and set the value from 3 to 2 but no help.
Got 256 Ram and a 20 Gig HD
  • brucesheffle Feb 08, 2009
    no it is a clean install and did this from the beginning . it has a blinking cursor at the top until it boots
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do you have lots of icons in the bottom right hand corner of the screen where the time is?
  • 73 Answers
A couple things come to mind - bad hard drive sectors that are causing the system to retry disk reads over and over or, a device driver or program trying to load that takes a long time to time out.
If your PC boots more quickly into Safe Mode, it's most likely something loading on startup.
If it doesn't, run chkdsk on the hard drive and do a full scan for errors.
Disconnect all your peripherals except keyboard, monitor and mouse. Boot again. Any faster? If yes, it's a device connected to your PC.
Disable your startup items using the method described here:
http://www.pchelpforum.com/windows-tutorials/10204-using-msconfig-disable-startup-programs.html
If your system boots normally now, add things back in to the startup sequence one at a time and test after each one to identify the culprit.
Posted on Feb 08, 2009
  • 596 Answers
This sound like a hardware compatibilty issue. What is the model of your NetVista?:
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
My Acer aspire one wont start into normal windows, only safemode
Did your system come with any software? I know when I bought my aspireone it did not. However, You can purchase a thumbdrive with at least 4 gb of space and if you have a copy of windows xp of the same version as that which is loaded on your aspireone (should be windows xp home edition) and you can use a program like magicISO to create a copy of the windows xp cd onto the thumbdrive.
Hope this helps, and I would be more than happy to give you more specific support as needed.
Good Luck!
Jesse
Jan 06, 2010 | Acer Aspire One AOA150-1635 Notebook
Netvista 6350 lost screen connection after BIOS password reset
If there a separate AGP Video Card in the system? If so, is there also a VGA connector on the motherboard? If you have both, try swapping the screen over to the other one. You may have reset the default video card back to the motherboard.
However, it looks as though you are using onboard video as you appear to be using 256Mb shared RAM for the video memory as your total should be 1536Mb.
In that case, you may need to do a rurther BIOS reset. You can find the complete instructions here
Nov 28, 2009 | IBM NetVista PC Desktop
Dell Vostro 200 desktop with Windows XP is not able to handle two
Vista doesn't generally like to be installed on a hard drive that big. Well, Windows, in general doesn't.
And, from the sounds of it, you didn't install Windows on your new primary 1.5TB drive, you just copied it from the 500GB drive, which won't work.
Here's what you should to, to solve this:
1) Swap out your 1.5TB drive with the 500GB drive again.
2) Swap out your secondard 1.5TB drive, with the new one.
3) Create a partition of 120GB or less on that drive
4) Install Windows on the new partition.
5) Put the other 1.5TB drive back in, as secondary.
Once that's done, you can swap out the new 1.5TB drive with your Windows partition on it, in place of the 500GB drive.
When you boot, Windows may ask you to select which operating system you want, just select Windows Vista, and you should be good to go.
I had a similar issue a few years ago, when I tried to install Windows on a 1TB drive, and couldn't get it to work. Once I partitioned a smaller space, it worked like magic.
Mar 20, 2009 | Dell Vostro 200 Desktop Computer Intel...
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
IBM Netvista desktop bios problem
this is more like a workaround that I used on a laptop which cd room drive just failed (and which I did not want to replaced as it was more expensive than the whole laptop)
If you can't select the device you want to boot from.. you may want to partition your hdd and format it so it loads a dos operating sytem .. use another machine and a win98 startup disk to do this then copy your I386 folder from your winxp cd into the new formatted hdd so when you put the hdd back into the IBM machine it loads dos and then going into the I386 folder you can run a winnt command for you to install the os.
Jul 31, 2008 | IBM NetVista PC Desktop
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
168 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
