Question about Lasko 5540 Ceramic Compact Heater
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
After overnight use of LASKO 5540 heater, found it's dead in the morning. Didn't use timer because having dead furnace. Guessing it's due to automatic shut-off Tilt Swich (safety) triggered by overheating. If it's true, where is this safety switch? How can I reset it? Right now, fan or oscilator is working. At low or high heating position, heating is OK, but fan is not working! Help! Thanks!
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Posted on Feb 15, 2009
    New Friend:
  • 3 Answers
I can only get to 49degess how do I get it to go up
Posted on Dec 07, 2016
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
Why does the cord get hot
if your cord is getting hot you should have it replaced with a heavier one or throw out your .heater. hot cords are a serious fire hazzard. if the heater is fairly new take it back where you bought it
Dec 09, 2010 | Lasko 5540 Ceramic Compact Heater
Made the mistake of sitting a towel on it momentarily. It shut done, never to work again. Easy fix?
The thermal overload switch worked like it was supposed to. You can open up the unit and see if there is a reset button between the two leads going to the switch. If not, throw it away. Sorry.
Mar 01, 2010 | Lasko 5540 Ceramic Compact Heater
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Absolutely no power to my Lasko 5540 heater
There is a thermal fuse in line with the power chord. Open your heater housing up and trace the power cord. It is located inside a white teflon sleeve. Locate the fuse and either replace it with the same value. Appliance repair shops will have them in stock. If you want heat right away, cut out the fuse and jumper the 2 wires together. Instant heat.
Nov 21, 2008 | Lasko 5540 Ceramic Compact Heater
Iflo digistat
Found a manual:
http://www.invensyscontrolseurope.com/InvensysControlsEurope/en/ProductsServices/Drayton/ProgrammableRoomThermostats/
Sep 20, 2008 | Lasko 5540 Ceramic Compact Heater
No power
Go to the Lasko Website and get a new one for free. They were recalled
Jan 17, 2008 | Lasko 5540 Ceramic Compact Heater
Popping, smoking electric Lasko 5540 heater
Connector for power cord overheats and shorts. Bottom safety screw can be undone using the bacj end of a jig saw blade.
Replace wire connectors with different wire connectors - wire nuts etc.
Nov 05, 2007 | Lasko 5540 Ceramic Compact Heater
Poping, smoking electric Lasko 5540 heater
It depends on where the smoke is coming from. If it's from the heating elements, it's normal as dust and residue burn off. If it is coming from the control section, it's bad and the heater should not be used.
Lasko 5540 Ceramic Compact Heater Logo
2,223 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
