Question about EuroCave Comfort 260 Collector's Package Wine Cellar - Black
Door warped....... The glass door on the Eurocave Comfort Model # 206968 is warped at the top of the door and can be seen as such visually. I can push in the top of the door with one hand and hold the other hand over the top and I can feel the increase in airflow as it pushes in. Where can I go (if possible) to find a replacement door?
  • t_mil Feb 18, 2009
    Thanks joboo1,
    Everything is level. The door is definitely warped outwards nearly one inch at the top. I was able to add another latch up top and this pulls it tight and seals and doesnt affect the bottom. My customer was also closing the door with the lock closed so it wasnt latched closed only pushed partially closed.
    Thanks for the suggestions.
  • 257 Answers
Hi, These cabinets have 2 sheets of tempered glass with an airspace between and are fully reversible I would doubt they are warped. My best guess is that the cabinet is not square. If you have a level, check it across the top of the cabinet not the door. Also check it diagonally both directions. The cabinet has feet which are adjustable unless you have a low spot on the floor for which you may have to use a shim. Remember that it needs to lean slightly to the rear for the door to close on its own if partially open. Good Luck to you! Let me know how this works for you.
Posted on Feb 08, 2009
Need a lock assembly and key for a EuroCave Comfort with a glass door 180. Dealer outrageous. Any alternatives?
unfortunately no. That is how they make their money. That said, you may be able to have a locksmith re-key the existing lock without replacing it.
Feb 02, 2018 | Cars & Trucks
Door will not lock unless you push extremely hard to close it
It sounds like the lid is warped or bent sometimes by putting basket on top or laundry detergent. Also sometimes kids sit ontop
Sep 12, 2014 | Washing Machines
Excess condensation in my eurocave 266
Check the door seal gasket is sealing without any gaps. Check the ambient temperature isn't too high, and check the condenser is clear and aired.
Apr 20, 2014 | EuroCave Comfort 266 Connoisseurs Package...
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Problem with compressor
it is entailed process and you would need axcess to torch oxy-acc w #2 tip and silver solder, a evac pump, deep vac pump and container to capture the old freon usually compressors come with a new filter and the electrical parts per normal without sweep charge this process can take up to 4hrs to perform not for the unskilled if you do not remove the moistier from the system the new will fail shortly.....sorry for the news its be done by a professional...
Aug 19, 2009 | EuroCave Comfort 260 - Black Solid Door
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort 260 Collector's Package Wine Cellar - Black Logo
238 people viewed this question
Top EuroCave Furniture Experts
mike cooper
Jim London
Jim London
Are you an EuroCave Furniture Expert? Answer questions, earn points and help others
