Question about Grindmaster Pourover Brewer - 18
How do I make coffee with a Grindmaster Pourover Coffee maker?
I recently inherited this coffee maker and would like to use it at my church. There are switches for the warmers, but no switch for brewing the coffee. Help - how do I make coffee?
  • Randy Hough
    Randy Hough May 11, 2010
    Can you post the model #
    President:
  • 2,559 Answers
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Posted on Feb 08, 2009
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
May 09, 2013 | Home
I have a VPR pourover Bunn coffee maker. I've had it many years with no problems. The cord is getting hot and popped the circuit breaker.
Most the time the plug goes bad.This is a cheap molded plug.You can pick up a new plug at the hardware store.Pick up a 120 volt standard 15 amp plug.
Feb 15, 2011 | Bunn VPR Coffee Maker
Water is still dripping after brew cycle is finished
If it is a plumbed in model then the inlet solenoid needs to be replaced. If it is a pourover model then check the temp the water in the tank might be boiling.
Aug 12, 2009 | Bloomfield E-Max 2012 Coffee Maker
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, and thank you.
Mar 05, 2009 | Bunn A10 Coffee Maker
Bunn ST15
Bunn's official position is that this brewer must be hooked up to a water line. The problem with using these as a pourover is the evaporation of the water. it doesn't take much of a loss of water to burn out the element in those models.
Feb 14, 2009 | Bunn NHB Coffee Maker
Grindmaster P400 New Airpot/Urns not keeping coffee hot enough
this is a normal problem! first make sure you fill too top! also heat up urn with hot water prior to adding the hot coffee!
Dec 09, 2008 | Grindmaster Coffee Makers & Espresso...
Inherited coffee maker I have a Faberware ?138? Automatic Peculating Coffee Maker I inherited from my Grandparents. It's in great shape but I have no idea how old it is. It's a great little unit, but...
There realy not much of a manual for this type of coffee maker. put water in to water line, put coffee in the metal basket, put the lid on the metal basket, put lid on the coffee maker, set it on the stove until it starts peculating let do it for 10-min then stop.
Sep 06, 2006 | Faberware FCP412 Coffee Maker
Grindmaster Pourover Brewer - 18 Logo
247 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
