Question about GE Spacemaker JVM1640SJ Microwave Oven
What screws do I loosen to get micro out of bracket.
I need to tighten the bracket holding the micro. What screws do I loosen to remove micro so I can get to bracket?
    Problem Solver:
  • 17 Answers
THE TOP SCREWS IN THE CABINET
Posted on Feb 08, 2009
How do i remove a JVM1330ww002 microwave
These usually have 2 or 3 screws holding them from the top. It may also be held by a rear bracket. Removing the screws will allow it to tip down and be removed from the bracket. I usually put a cardboard box (or similar item) under these when loosening the screws to prevent it from falling.
Aug 16, 2016 | GE Microwave Ovens
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
Mar 02, 2014 | Kenmore 66469 / 66462 / 66464 Microwave...
The door wont stay shut, the microwave works if I hold the door shut, I think it is the latches
The door is probably out of adjustment. Remove it from the power source.
Remove the top cover and examine the door catch housing. There usually are a couple of screws clamping this in place, loosen the screws, shut the door and tighten the screws.
Finaly, check the hinge for clearance, (No more than 1/10th inch), and adjust as needed.
Hope that helps.
Dec 21, 2010 | Hotpoint RVM1435 Microwave Oven
Removal of GE microwave model jvm1640AB004.built in 2001
requires two poeple who can lift or hold the weight of the micor. get a stool or lil ladder remove screws above that screw down inside upper cabinent usaually two maybe three sometimes while someone is below and holdin the weight of the unit so it doesnt drop once the screws are out. unplug the unit and also remove the tape if any and free it of its ductin pipes if vented above. once screws are out help lift micro up and out as it is postioned usually on a wall bracket that has lil clips that slide into the bottom back corners of the micro lift up and out to free it fromt the bracket, once out feed cord through hole uusally cut for it,.. hope this helps
Feb 03, 2010 | GE Microwave Ovens
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Jan 09, 2010 | Sharp R-1480 Microwave Oven
I have removed the mounting brackets from the top of the microwave but still cannot get it to tilt forward for removal. I do not see any levers as suggested in the Solution #1 above. Any other advice?
Did you remove the 3 screws from the top that hold it to the cabinet. Here is a install manual so you know what screws to remove. also make sure the ducting is removed all the wat to tilt micro.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495064.pdf
Good Luck
Nov 21, 2009 | Frigidaire FMT118EPB Microwave Oven
How to get sharp r-1440 disassembled from under
Probably don't need this anymore, but there is another post, which we added to. Hope you had success.
Be sure to unplug first.
It is mounted on a steel bracket which the micro was tiled into place on. The bracket covers the entire area of the wall where the micro sits.
Basically, two screws in the bottom of the overhead cabinet, and two more screws located in the venting area of the microwave (under). Take the vent filter covers off each side, and remove one screw on each side carefully. If you take the fan cover off in the top front, you can see the steel support on the left.
Two people: The micro is then lifted up and off the support slightly, and then tilt forward to remove.
Jul 15, 2009 | Sharp Microwave Ovens
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
GE Spacemaker JVM1640SJ Microwave Oven Logo
52 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
