Question about Toshiba Satellite A205-S4617 Notebook
Monitor showing imagens in horizontal position
I've bought recentely a Toshiba satelite 200, it was working fine, but suddnely the imagens in the monitor appear in horizontal position instead of verical to be more precisely like a book turned in the horizontal position.
Please assist me, what can I do fix the problem.
N.Serafim
  • 73 Answers
Toshiba has a screen rotate utility. Try hitting Ctrl + Alt + Up Arrow on the keyboard.
Ctrl + Alt + Left Arrow or Right Arrow may work also.
Posted on Feb 08, 2009
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
MY TOSHIBA SATELITE A200 - TH1 LAPTOP WILL NOT RECOGNIZE MY SAMSUNG 2243BWX MONITOR THIS MORNING. I HAVE CHECKED THE CABLE AND UNPLUGGED IT AND REPLUGGED IT REPEATEDLY. I HAVE A SECOND MONITOR FROM...
look on keyboard you will see two symbols of monitor in a single key which may be from f1 to f10. connect monitor and press that key laptop will recognize the monitor
Feb 02, 2011 | Samsung 2243BWX Monitor
Buens noches..tengo un monitor DELL2005FPW 20.1
Creo que tienen capas superpuestas de la misma imagen en su monitor. Prueba a revisar los cables doblados o dañados. Ver si hay dispositivos electromagnéticos cerca del monitor. Por una vez, intenta huir de la liberación de la energía de la pantalla. Para ello, desconecte el cable de alimentación del monitor y presione el botón de encendido en el monitor durante unos 15 segundos. Usted puede también intentar el control de la imagen en modo seguro de "Windows". si la imagen está muy bien allí, es necesario volver a instalar / actualizar los controladores de vídeo.
ENGLISH: I think you are having overlapping layers of same image on your monitor. Try checking the cables for bent or damaged pins. See if there are any electromagnetic devices near the monitor. For once, try releasing the flee power from the monitor. To do this, unplug the power cord of the monitor and press the power button on the monitor for about 15 seconds. You can also try checking the image in safemode of "Windows". if the image is fine there, you need to reinstall/update your video drivers.
Oct 15, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Toshiba TV -- horizontal line
sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Apr 20, 2009 | Toshiba Televison & Video
Toshiba Satellite M30 - Power Problems only boots when in vertical position
These are known to have a grounding problem between the speakers and mainboard - They were actually sued and eventually settled to extend the warranty. unfortunately the special extenstion program ended a few months ago and toshiba no longer will fix this. The workaround is to add shielding to it.
See this link about it:
http://www.laptoprepair101.com/laptop/2006/04/06/satellite-m35x-a70-a75-lockup-freezes-reboots/
If that doesnt fix the problem then you may have motherboard problems and at that point it would be best to part this laptop out and replace it.
Dec 21, 2007 | Toshiba Satellite M30X Notebook
Inverted monitor
reinstall the diplay drivers and try once ... hope u have tried default display settings ...
Dec 10, 2007 | Toshiba Satelite A10 Notebook
The computer shows error message at start up
check the bios. Something may of changed. How old is it? Maybe the bios battery is bad.
Oct 20, 2007 | Toshiba Satelite A10 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
