I plugged charger on my cobra 7700 power light turned on for second and wont turn unit on
SOURCE: i just bought a cobra
check the manual to see if it tells you how to unlock it if that dont help you check with the place you bought it or look up the manufacter you made it and try and get it unlocked by them hope this helps you.
SOURCE: My cobra gpsm 3000 needs to be updated and cant
If it's a NAV ONE 3000, then the link below will get you to the site with instructions.
https://cobra.com/softwareupdates/navigationlist.cfm
SOURCE: no system file on my
call the cobra customer service at 1-773-889-3087
give them the serial number from your unit and they should mail you a disc that you run on your laptop to reprogram/update your gps, and there should be no charge. so until then your s.o.l
SOURCE: Where do I get an unlock code for my cobra gpsm
unfortunately, if you locked you unit and dont remember the passcode, the unit has to be sent in to cobra because they are the only ones that can unlock it. Its an anti theft measure. Their contact number is 1-773-889-3087.
