Unit so I can copy some old VHS tapes to DVD. Or is there a DVS that I can hook up to the combo unit without hooking it up to another VCR.
SOURCE: TRUTECH/DAEWOO DVD RECORDER/VCR DRT-S810
Hi!
did you check the +5 volts if exactly? and the +9voltsif exactly? now
if you got over voltages in the said voltages you got abnormal power
oscillation! or did you check the regulator? maybe the ADJUST Pin is in
abnormal function! and try to unload the power board then you can test
run the power board by checking the voltages in secondary.
SOURCE: VHS to DVD recording
DVD Recorder/VCR combo .Vcr sound distorts vrey much about three second after Vcr is turned on?
SOURCE: I NEED A MANUAL FOR A DAEWOO DF4150p dvd recorder/ vcr combo please help
Click here to get the user guide for your device.
SOURCE: magnavox dv225mg9 dvd/vcr player. Hooked
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
