Question about Dell A215 Computer Speakers
Speakers not plugged in?
Hi, i've been trying to solve this problem for 1 month don't have time to bring my cpu in a repair shop coz of my work. i have an ASUS P5SD2-VM motherboard installed with a VISTA 32bit. my problem is when i look at my playback devices the speakers is greyed and says not plugged in. only ATAPI INTERNAL is working. i tried installing the driver from the cd same thing happens. i even tried DL some drivers from realtek but still not plugged in. from the realtek settings the at the analog the rear panels are greyed while the front panels are active which makes me crazy coz i don't have front panels. i also tried the process like uninstall then install the realtek but whenever i restart vista is automatically install the RHDA and there comes again the ATAPI. i really would appreciate any help i can get. thanks...
Hello sir,
Immediately post  the  problem in my address i can solve the problem
34,vpm road Koothanallur-614101 Thiruvarur-DT Tamil nadu-state India
Posted on Feb 08, 2009
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
My speakers don't want to turn on
Hi ,
Sometimes , new speakers just don't work from the beginning and you need to bring them back to the retail shop under waranty .
Before doing that , check your soundcard by connecting it's output to another sound set , like your hifi or another speakers set . If this doesn't work , you could be just facing a driver issue that can easily be solved by downloading and installing the correct driver from the manufacturer's site .
Feb 09, 2013 | HP Harmon Kardon 5187-2105 Computer...
Sony ericsson j20i speaker problem
When the speaker does not work, there can be different causes. Something got in the headphone plug, preventing the connection to the speaker when the headphone plug is out. Another bad connection in the phone, or even a defect loudspeaker. When you are no tech, just bring the phone to a repair shop and let a tech review the problem.
I would blow in the headphone connector with a bellow a photographer uses to blow away dust from the lens and sensor. DONT blow in yourself, because of the moist you bring in. And I would plug and unplug a few times to see if that can solve the problem. Not to often and if it does not help? please do option 1 visit a tech.
Apr 04, 2012 | Sony Ericsson Hazel J20i GreenHeart...
Hi i have LOGITECH X540 5.1 140W SUBWOOFER SPEAKERs and couple of months ago one day my speakers worked properly and it didnt work after i came home from work. i havent had time to look at it but i need it...
Hello, the problem can't be fixed in a couple of minutes, not even in a couple of hours, I recommend you to take the speaker system to an electronic technician to fix it for you, use a borrowed sound system while the other is repairing, and to avoid that problem from happening again turn it off whenever you don't need it.
Too bad I had to give you the bad news. I still wish you have a nice day.
May 28, 2011 | Computers & Internet
I've taken my eton matrix 150cc (2009) to the dealer twice in the last two months for repairs. The bike has lost most of its power, it doesn't pick up and go like it use to. I can only reach top...
sounds like the spark plug is breaking down under pressure have you replaced it with a new one?
also check you have good compression when you remove the plug put your finger over the hole in the engine head and try and start the bike your finger should be pulled into the bike slightly then will be a slight sucking noise if it isnt then it would be worth taking of the head and checking the piston rings
hope this helps
John
May 16, 2011 | Eton Racing 501 Basic Motorcycles
Gateway MX6920 won't power on.
You Need To Replace The DC Jack In The Laptop...
It Is The Jack THat Your AC Adapter Plugs into....
The Jack Needs to Be Unsoldered/Removed/Cleaned And A New Jack Installed..
I Wouldn't Bring It To That Same Repair Shop To Do THe DC Jack Repair FYI...... ouch!!!
http://www.ifixlaptops.com
Nov 16, 2008 | Gateway MX6920 Notebook
No Sound
You need to have some one check out the main board and see if the audio amplifier is out. This should have been what they tested in the repair shops. If this is true then you need to get the part number and try to find the part and have someone replace it for you.On the hand this may be a problem with the speakers and speaker connections. a Then you just need to repair the connection or replace the speakers. The best way to find help for these repairs at low cost is to find local schools that teach Television repair courses and allow people to bring in their Televisions for repair at the cost of parts only. The only problem with this is that it may take some time for the repair and getting the parts if available. You can speed up this process by helping them locate the parts and going to get them.You can call TruTech customer service at these numbers for help find parts and technical assistance : 1-800-525-6123 and 1-888-525-6252. I hope this helps you with your problem.
Jul 22, 2008 | TruTech PLV16320 Television
The sound disappear
Can you tell the exact model of your motherboard. I will try to find an audio driver for it.
Oct 23, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Dell A215 Computer Speakers Logo
165 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
