Question about Metz 60CT-1 Flash
Flash Head Loose on Metz 60CT-1 Flash Unit.
Flash head not staying at indent positions when head is tilted upwards for bounce flash.
3 Suggested Answers
SOURCE:
  • 216 Answers
SOURCE: Flash doesn't fire properly at regular position
Did you buy this used or new?
If used: neck has broken/shorted wires.
Try fires with the Test Button in A mode with hand blocking sensor and then without. Move head around.
If I can help.
atdlee@netzero.com
Posted on Dec 30, 2007
  • 216 Answers
SOURCE: Can't fire properly at 90 degrees
Are you still having problem(s)?
Posted on Jan 28, 2008
Metz 60ct-1 manual
USE A REMOTE FLASH TRIGGER I USE IT ON MY 60CT FLASH ON 5D11
Apr 07, 2012 | Metz 60CT-1 Flash
Where will a found serial no. on metz 45 cl-1flash gun?
Raise the tiltable head the number is embossed below it(at chin side).Near hinge.
That means if you tilt flash head fully upward the number is exactly at the opposite side of Flash power calculator dial(Two inch round chart).
Apr 17, 2010 | Metz 45 CL-1 Flash
How do i increase or decrease my power on my metz 60-ct?
The dial on the top does nothing to the flash. It's just a guide, like a simple ruler.
Example:
You just set your ASA/ISO (Yellow Line) to Orange DIN/ASA Number to match your camera's ASA/ISO.
Then just read those Scale of F Stops to outside to get FT/M (Feet or Meter).
The true meter from flash is on Handle of flash:
Set Orange Horizontal Line to ASA/ISO Number to match camera.
Set Left Slider, push up & down, to the F Stop that you wanted to shoot.
You have 6 Auto Sensor F Stops
1 for M (Motordrive)
1 for W (Winder)
Hope they are helpful on all photographers using Metz 60CT-1 Flash.
Truly,
atdlee@netzero.com
Apr 21, 2009 | Metz 60CT-1 Flash
My 60CT-1 only fires at full power. Worked fine one day the next time I used the unit it would only fire full power each flash.
Is the top dial set on AUTO?
Is the sensor window clean or obstructed?
Checking both of these may solve your problem. Do you have a Manual for this flash? There are free pdf downloads on the I/Net.
Jun 16, 2008 | Metz 60CT-1 Flash
60ct4 metz flash head
Hi Canday, As the connections are OK, it is possible that a lead inside one of the wires is broken. You don't say if it powers up or not, so it is very difficult to give more specific advice or diagnosis. It is a professional unit, so I suggest you take it into a top camera shop for their advice. Good luch, John Hannah
Apr 05, 2007 | Metz 60CT-1 Flash
Did you buy this used? Maybe the following problems: wires inside are loose or cold soldered. Flash tube has coated with film coating or flash head(inside)is dirty. Alexander atdlee@netzero.com
Jan 13, 2007 | Metz Mecablitz 60CT4 TTL Flash
If I can help.
atdlee@netzero.com
Dec 31, 2006 | Metz 60CT-1 Flash
Metz 60CT-1 Flash Logo
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
