Question about Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive
Buffalo Ministation does not show up when it is plugged in.
I have just recieved this harddrive and am trying to use it but cannot as it does not show up in my computer or anywhere else on the computer. The green light is on on the box... what should i do!
please help
sar
xx
  • noblebasha Feb 21, 2009
    I also have same problem....Some computer it gets detected...so computer it shows USA not recognized. Please let me is there any problem with USB connectivity??
  • Anonymous Apr 14, 2009
    Same. Green Light comes on and I can hear drive start but it is not visible on my computer to open.
5 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: xp cannot install this hardware. Buffalo
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Sep 24, 2009
Testimonial: "very helpful advice and correct also. I had changed the usb lead and it cured the problem."
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
Posted on Jul 07, 2009
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
  • 224 Answers
SOURCE: I have a buffalo ministation
It is possible to recover data after formatting. This guy does it remotely and works off of donations http://FreeDataRecovery.us
Posted on Jul 24, 2011
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
Data error(cyclic redundancy check)
harddrive is dead or bad sectors, try using vivard on ultimate boot cd to fix it
Oct 27, 2013 | Buffalo Technology Buffalo MiniStation...
Have recently had to add windows 7 to my PC (losing everything) but have laptop using XP. When I plug buffalo ministation into PC it wants to format but I'll lose everything on harddrive won't
click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 12, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Just purchased buffalo ministation and it shows as full
Try this ...
Depending on your operating system, you will need to find the Disk Manager (not the Hardware Manager).
In the Disk Manager you will see your harddrive but possibly no Drive Letter associated with it. It should give you the option to format the disk and assign it a letter.
Aug 05, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Cannot access data in my buffalo ministation orange light showing,after it fell down
Jul 07, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Simpletech 160 Portable doesn't show up
because it is not properly connected.connect it well.
Jan 13, 2009 | Computers & Internet
Buffalo ministation
Oct 18, 2008 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Logo
2,143 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
