Question about Dell 922 All-In-One InkJet Printer
Power light keeps blinking on 922 dell printer
The booklet says to check for paper jam, there is no paper jam, I had lost electrical power durning the day and when I noticed the light it was blinking. Worked fine before losing power. Maybe AC adapter?? any help would be appeicated
  • Anonymous Mar 01, 2009
    I have the same problem, blinking light and no paper jam. The power button does not either turn printer on or off...it just blinks when plugged in.
SOURCE: Looking for AC Adapter part no 21D0315
Hi! Are you still looking for that Adapter? I have it. If you are still intersted, please call me (Ray) at: (416) 752-7600 or (416) 633-1014. Or send me an email to: ray.cadis@gmail.com I was about to post that AC (Part No.: 21D0315)on ebay! (We are in Toronto canad)
Posted on Jan 17, 2007
jrutt17
  • 34 Answers
SOURCE: Dell 1710n Printer - All lights blinking and no response from printer
Did you try Printing the Printer Settings Configuration Sheet?
Posted on Jul 28, 2007
SOURCE: Dell photo printer 942 all in one paper jam
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Alternately you can also try to download the and install the printer drives form the support site if the paper jam message is being displayed on the computer’s screen but not on the printer’s LCD screen.
Should you require any further assistance regarding the printer or even any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Jan 31, 2008
IB4G2008
  • 3587 Answers
SOURCE: Dell 922 all in one paper jam
maybe following this list of suggestions might be of some assistance?
Posted on May 03, 2008
kram26
  • 544 Answers
SOURCE: Dell 922 printer. No paper in machine but it tells me I have a
can you please open again the cover of your printer and double check maybe there was still paper inside even a tiny paper will caused a problem.
thanks.
Posted on May 21, 2009
My Dell All-In-One printer is not printing at all and the paper comes out blank. I need help.
Ensure that the printer power cable is firmly connected to the printer and the electrical outlet
Determine if the printer has been held or paused
  1. In Windows XP, click Start® Settings® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Double-click Dell Photo AIO Printer 922, and then click Printer.
  2. Make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to deselect it.
Check for flashing lights on the printer.
Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge
Make sure you loaded the paper correctly
Jan 19, 2011 | Dell 922 All-In-One InkJet Printer
Printer power on. turned off to change cartridges. turned back on wouldnt print or copy. unplugged power and usb cable to allow printer to reset. plugged back in per instructions, get blinking green light...
Hi Good day!! Please try to restart your printer spooler..
1. Click "Start"
2. Click "Settings"
3. Click "Control panel"
4. Click "Administrative tools"
5. Click "Services" you should be on services box now.
6. Find "printer spooler" after that click stop and then re enable it. hope your printer works now...
Oct 13, 2010 | Dell 922 All-In-One InkJet Printer
My dell 922 printer say there is a paper jam but there is no paper stuck in the machine
check the full inside of the machine, even a small piece of paper in some of the spooler inside can cause the printer to malfunction.
Dec 07, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
922 Dell Printer Problem
either the gears of the paper feeder are cracked or misallignewd and needs to be replaced or readjusted or the sensor which detects the paper in the tray is broken. so you r facing this error. please check it out. it will solve your problem.
Oct 26, 2008 | Dell 922 All-In-One InkJet Printer
Aio 922 power light constantly blinks on and off, will not turn on/off or communicate with computer.
Try to unplug the power cable as well as the USB cable of your printer for few minutes. Then plug it back in, check the lights again.
Oct 09, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 printer jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
May 03, 2008 | Dell 922 All-In-One InkJet Printer
Problems with Dell 922 All-In-One InkJet Printer
check to see if the ink cartridges are installed properly, or if there is a paper jam. If not unplug it for 2-3 minutes, and try using it again.
Jan 09, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
249 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
