Question about Frigidaire Affinity ATF7000E Front Load Washer
Washing machine won't start. when hit start 0' displayed
I closed the door, pressed normal cycle 43 min displayed. When I pressed start 0' displayed. When tried to cancel - delay time displayed, hit cancel again, more time on delay.
    Problem Solver:
  • 12 Answers
Look like the PCB board problem and have to look for a repairer, alternative is look for a PCB board of the same model and fix up to test if the PCB IS THE COUPRICT.
Posted on Nov 02, 2014
  • 257 Answers
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Posted on Feb 08, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Ultima washing machine reads test in the window
I read your other entry first ;-0)
You will have to find the date code- on the rear panel perhaps- then here are your options-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both star/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 16, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My clean light is flashing....call service to check heater?
f the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
E-43 still after a new control board
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin lights should light. Any error codes should be displayed when holding those keys.
May 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
316 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
