Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 power problem
My canon pixma ip3000 will not power up
  • 2 more comments
  • Anonymous Mar 28, 2009
    I am unable to get power to start the printer
  • highlandhawk Apr 06, 2009
    I have a canon ip3000 printer and it was working fine until this morning when I went to turn it on. When I turn it on it does nothing, no light, nothing. No power at all. What could the problem be? Thanks
  • David Rawlings May 03, 2009
    I have exactly this same problem. The power supply K30233 pulls out and I opened mine up but couldn't see anything obvious wrong. I checked the +24V and read nothing to ground. There's another terminal designated "CONT" not sure what that means.
    Did yo solve your problem?
  • ostseedoc May 04, 2009
    My Canon does not power up at all. I tried to push in the cable real hard. Nothing. Please help
    Problem Solver:
  • 13 Answers
The cord is a tough one. but it has to be pushed in very hard in some models. are you sure it is plugged in at the back of the printer hard? push extra hard.
Posted on Feb 21, 2009
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Installed printer will not print
I found a vista driver for a Pixma ip 2600 and downloaded it. My printer now works but the black ink doesn't. Don't know if it's a driver issue or otherwise. It might be worth a try for you. There are no available vista drivers for the ip3000.
Aug 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error 6A00
6A00 is AP position error. Check sheet feed unit.In worst case the logic board assembly is defective.
Mar 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lost my set up disc for my Canon ip 3000 printer
Sir,
Click this link to get ur software / driver
Thanks
good luck
Nov 26, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Installer cannon pixma ip 3000
http://downloads.cnet.co.uk/0,39100207,39187982s,00.htm
Sep 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
577 people viewed this question
old marine
old marine
