I formatted my HP pavilion using UBUNTU. Then i tried to install XP however it says that it is not able to detect my hard disk while insatlling the . i do not know if my hard disk has crashed or some minor problem which can be fixed?
I also tried the laptop to self check the hard disk. however that too failed. the steps were after switching on > F10> diagonostic> detect hard disk. And it says the status as failed.
So do i need to change my hard disk as i do not know if it has crashed?
UBUNTU is a version Linux its formatting is different than Windows. If you are trying to setup a dual boot system (ability to boot linux or windows) my suggestion is that you partition the HDD install windows on one partition and then windows on the other. or just use seperate HDD. >>>> If you just want windows installed low level format the HDD and windows should be able to recognize the drive. >>>> you can low level format using POWERMAX - download and burn to cd >>> powermax4.09.iso
go to http://digilander.libero.it/YorkOne/powermax/ >>>> the cd will be bootable just pop it in and reset
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion dv6000z 15.4"
HP Pavilon DV6 laptop running windows 7 MTP USB device has a driver problem error message when I...
(More)
HP Pavilon DV6 laptop running windows 7 MTP USB device has a driver problem error message when I plug in my iPhone
My laptop seems to be tweaking out. whenever i click something it will click it more than once. also...
(More)
My laptop seems to be tweaking out. whenever i click something it will click it more than once. also if i click somewhere on the screen it will highlight things sround it. click lock is not on. im thinking the problem has something todo with the left mouse button. can someone please help? this problem is interfering with typing up papers i have due!
i have a built in web cam what wont turn on can u help? its an hp Pavilion dv6000 and when i try to...
(More)
i have a built in web cam what wont turn on can u help? its an hp Pavilion dv6000 and when i try to use it for exaple: I tryed to use on Window Live Messenger but it said it was in use with another application what do i do?
I have a sparten lap top--trying to use web cam via skype-it wont rec. the web cam-(used to but wont...
(More)
I have a sparten lap top--trying to use web cam via skype-it wont rec. the web cam-(used to but wont today??)
My AMD-8151 Hyper Transport (tom) AGP 3.0 Graphics Tunnel also doesn't work properly because Windows...
(More)
My AMD-8151 Hyper Transport (tom) AGP 3.0 Graphics Tunnel also doesn't work properly because Windows couldn't load the drivers required for the device (Code 31)
