Question about Haier BC112G Wine Cooler
Temperature gets and stays around 40 degrees then back freezes up
The past few months we noticed the wine cooler stayed at around 42 degrees regardless of how we set it. The back a bit of ice. We defrosted and reset it. Went down to 42 again and completely got icy in the back. My husband thinks it should just be thrown away. Is this a problem that can be fixed moderately easy. We have no handy man in htis house.
  • tcjdunn Feb 08, 2009
    I checked the "fins" I believe they are the blackpanel behind the fridge. Minimal dust with a silver back of the fridge behind it.... That is what you are talking about isn't it? So if there is no dust on these and the fridge ices up. You feel it is the compressor and just throw out?
    thanks alot! You saved me the trouble of taking it somewhere to be told it was a waste of time!!
Unit may be a little low on refrigerant or a faulty thermostat. Worth repairing if you are thinking of replacing a new one. A little dust on the fins at rear has nothing to do with your freezing up problem.
Posted on Jun 12, 2009
    President:
  • 1,902 Answers
Have you checked the fins in the back to make sure that they are clean and not clogged with dust. If you have or you do not have any then your compressor is bad and you are best just throwing it away. If you have fins back there, use a spray bottle with hot water and put a towel under it and just spray and spray and spray until you can see through it with a flash light
Posted on Feb 08, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 08, 2009
    Yes, there are only two reason why a freezer or frig will ice up, Dirty coils which are the fins in the back, or the compressor has gone bad
  • Jeremy Reddick
    You are welcome have a great day
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
Jun 19, 2012 | Refrigerators
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Haier BC112G Wine Cooler Logo
280 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
