Question about Kenmore 64702 Top Freezer Refrigerator
Ice maker not freezing ice and water puddle beneath refrigerator?
I had a diner party last night. I emptied my ice bin in my freezer. I put it back and made sure the bar was in the on position.
When I got up today I noticed a peculiar sound coming from the fridge. It sounded like the ice maker motor doing it's thing but heard water dripping. I looked and there was no ice. Just a pool of frozen water in the bottom? Once again I made sure it was on. An hour later I heard dripping water again investigated only to find a puddle of water beneath my fridge! The drip pan under the fridge is full to the brim and still no ice!? I turned the valve off to keep water from running to the ice maker and shut off the ice maker. I hope this prevents it from getting worse while I diagnose the problem. What on earth could this be? Is my fridge dieing? Help!!
  • 236 Answers
SOURCE: Water leaking inside refrigerator
at the back of the fridge there is a water drain hole. this will be blocked. you will have to unblock by pushing a thin wire etc down it, then pour a little warm water down to confirm it has been unblocked.
Posted on Jun 02, 2007
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Posted on Jun 07, 2008
  • 29 Answers
SOURCE: drip pan overflow
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
Posted on Jun 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Posted on Jul 01, 2009
  • 1606 Answers
SOURCE: Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Posted on Sep 02, 2009
empty freezer put a pot of boiling water under the ice bin and let it melt it
May 10, 2016 | Refrigerators
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from - i see no dripping from anywhere but it sits in puddles on the...
I have a Whirlpool Top-mount refrigerator. Whirlpool also manufactures many of the Kenmore refrigerators.
A few weeks ago I noticed a puddle of water on the top right shelf in the refrigerator section. I figured out that it must be the water that forms during the defrost cycle and normally drains down through a tube in the back into an evaporator tray beneath the refrigerator. Something was preventing the water from draining away and instead it was dripping through the overflow holes from the freezer into the refrigerator section.
I emptied the freezer and took off the back panel. It actually wouldn't come off at first because all the water beneath the defrost heater which should have been draining out the drain hole was frozen into one solid block of ice. I used a hair dryer to melt the ice (took a while - be patient) and then took off the panel.
To melt all the rest of the ice in the drain tube I used the hair dryer. To clear out the ice in the drain tube, I used a turkey baster and kept putting down hot water until I heard water making it down to the evaporator tray beneath the refrigerator.
The following mod is "try at your own risk" (I wouldn't do this if you still have warranty coverage - call a tech instead):
I made this modification to prevent the problem from recurring (at least that's the hope): Wrapped a piece of wire (unbent a large paper clip) around the defrost cycle heater and stuck it into the drain hole. The theory is that the wire will heat up every time the defrost cycle runs and will keep the drain hole from freezing shut.
One thing I noticed during this repair concerns the drip pan beneath the defrost heater in the freezer (this is the pan that collects the water that is melted off the coils during defrosting). The drip pan does not seem to be angled properly so that the water will drain normally towards the drain hole. I guess water could remain behind then freeze later. I reported this to Whirlpool.
Mar 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
Firstly put off the refrigerator before the compressor burns off.
The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Kenmore 64702 Top Freezer Refrigerator Logo
186 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
