Question about Toshiba Satellite A135-S4527 Notebook
Can't get a ethernet connection to my lan connection
Tried a usb 2.0 to Ethernet Converter when cable connector didn't work-
  • 1 more comment
  • Jan Tjernlund
    Jan Tjernlund Feb 08, 2009
    Trying to connect Notebook to my cable modem to have cable internet access on my laptop. My work is giving me remote access to a citrix network but I need to have it for both home and travel. My home computer is connected to a printer
  • RM Pro Svcs May 11, 2010
    Swap network cables?
  • Nouveau IT, LLC
    Nouveau IT, LLC May 11, 2010
    What are you trying to connect? (NB to network, printers....) Thanks
Dvd&cd/rw not working
Posted on Feb 08, 2009
How do you connect the hp pavilion ze4600 with Ethernet cable
The ethernet (LAN) port is on the back right corner next to the USB plugs. From the far right, the plugs are as follows: power plug, USB, then LAN. Plug the ethernet cable into this port.
Sep 20, 2012 | Computers & Internet
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
2. Select "Wii Settings".
3. Click the left arrow to get to Wii System Settings 3
4. Choose "Wii System Update"
5. Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Apr 03, 2011 | Nintendo Wii Console
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
http://au.ps2.ign.com/articles/366/366021p1.html
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
Internet.
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
http://www.funadvice.com/r/3js7klmkua
May 20, 2010 | Sony PlayStation 2 Slimline Console
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Totally cannot run!
have you got your lan card drivers installed and is the windows firewall blocking connection as this can cause problems also check that the device is not being shutdown in windows newtork manager, if problem persists then get a converter to change lan to usb and install drivers for camera. good luck on connection.
Oct 03, 2006 | Axis Communications 2100 Network Camera
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
