Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Yard machine 139cc will only run short time with choke
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy. Almost like pressure builds in the tank and won't stop... yet the mower will not run.
HELP... and thanks
  • kaptaintramp Feb 08, 2009
    Where is it located... and how to I get to the carb?
    I know... never worked on a small engine before...
    and hey... thanks brother..
    Go Army
I have the same problem with my 139cc model, but no leaking gas. it just runs in choke on only.
uuuughhh!!!
Posted on Jun 10, 2010
    President:
  • 1,902 Answers
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Posted on Feb 08, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 08, 2009
    Your carb is right under the air cleaner next to the exhaust. If you removed the aiir cleaner you will be able to spray carb cleaner in there. If you are still having problems I will look for a manual for you to download.
    #1 Army thanks man appreciate it
Wont start
Your problem may be in the kill switch. To check, spray some starting fluid into carburator directly and pull start. If it sputter runs for a few seconds then dies chances are the kill switch is choking engine trottle as a built in safety feature. If you have to hold a bar down while pulling cord, that disengages the switch. You should be able to see if cord extends. If it's kinked I would replace the entire cable. It's cheap and relatively easy, just pay attention to how you take the old one off. B&S engines are very basic and very easy to fix.
Sep 12, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Crazy question but where is the primer button on the yard machine 139cc 21" lawn mower???????
The primer button is usually on the carburator of your machine. Most of the time on the side of the carburator , but sometimes on the front of the carburator. GOOD LUCK.
May 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Model 54 m runs only on choke for a few then dies
Change out old fuel,change in line fuel filter if there is one - you may have one in the tank, remove and clean carburetor passages - be careful with the gaskets - if you do not tear them they can be used again - make sure screws are tight. You might have to make adjustments to your mixture screws if applicable on the carburetor,clean air filter and plug. Recommend the new E3 spark plugs.
May 02, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
My 3 year old Yard Machine 139cc started (choke out), but then began running excessively fast after pushing the choke back in. A few weeks later, it still started (choke out) but now ran very fast even...
Check the carburetor see if all the bolts are tight.check the cylinder head gasket take off plug wire make sure it is away from plug so it wont start. Pull start rope can you hear air being pulled into the engine? if so the head gasket has ruptured or head bolts came lose. Ensure all parts are tight. Ensure fuel lines are not clogged. Check fuel level.
Sep 11, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy....
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
Yard Machine 20HP TWIN runs but when you take off choke it Dies!
remove carb and clean the main fueljet
it is gummed up due to set to long with
gas in it.
Aug 04, 2009 | Garden
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Tractor won't stay running
You will have to pull the carburetor off and rebuild it. This means cleanig and adjusting. This should help your cause a bit. donnyb60
Mar 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
828 people viewed this question
Top Yard Machines Garden Experts
Dwain Pippen
Jim Parker
Jim Parker
Kiltnar
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
