Question about Dell Dimension 8400 PC Desktop
I have a Dim8400 when starting I get 2 beeps then a black screen
That says diskette problem no floppy disk, which is true. I dont have one in my computer.It says press F1 to continue F2 for set-uo.
  • tipu28 Feb 13, 2009
    I did for mine, disable floppy disk option in set menu but I still have this problem
    President:
  • 1,902 Answers
You need to go into setup and disable the floppy drive. It detected a floppy drive due to a USB cable or a flash drive being installed on your computer.
Posted on Feb 08, 2009
    President:
  • 846 Answers
Ok to fix that go into your bios when your starting your pc F2, Del are usually the common buttons to get into the bios.
Once in there will be an option somewhere for boot floopy seek, disable it and you won't have that problem anymore :)
Thank you for stopping by Fixya! Feel free to leave positive feedback if this helps.
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Cannot access documents on remote diskette drive
ok this is definitely 1 of 2 problems.
1.) the diskette drive is damaged..
2.) the disk them selves are bad. These disk dont last very long and develop a white fungas on the magnetic disc itself.
to be certain get a disc you are re is working ,, and try it on a machine with a drive for it (dont know if they still exist).. if the disc works and does not work on your machine get a new drive..
if the disc don't work well then they are bad.
Dec 29, 2012 | IBM Wheelwriter 70 Series Ii Typewriter...
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps you
Oct 19, 2011 | Computers & Internet
Black screen with Diskette drive 0 seek failure on it. pressf1 to continue, f2 to enter setup
diskette drive o or disk drive o? f2 to enter bios check boot options to boot on drive o [hdd-0], most boot options go floppy,cd-rom, hdd-0
Feb 04, 2010 | Dell Inspiron 530s Desktop Computer
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Cant start my sons dell e520 even from the recovery disk. Keeps looping back to black screen and message floppy diskette seek failure.
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Nov 29, 2008 | Computers & Internet
My sons dell e520 wont start . i get the windows starting screen then it switches to a black screen with the messag floppy diskette seek failure then the options f1 to continue or f2 to run the set up...
Please vote if this was helpfull :-)
Nov 29, 2008 | Dell Dimension 4600 PC Desktop
Metal sleeve
3.5" FLOPPY DISKETTE
Below we have represented a picture of the now commonly used 3.5" floppy diskettes. The below representation is what the back of a floppy diskette looks like. As you can see there are four main visible parts:
floppyd.gif First, the top left of the back of the floppy there is a small tab. This tab enables the floppy disk to be switched from write protected and un-write protected. Move the tab to the top position, creating a hole, makes the disk write protected. This means that nothing can be written, erased or deleted from the diskette. Moving the tab to the bottom position allows the disk to be un-write protected, which means the diskette can be written too, erased, and or have information deleted from the diskette. Some diskettes, which are generally cheaper diskettes, will be missing this tab. To write information to the diskette you will have to place a piece of scotch tape over the hole.
Second, the top right hand of the back of the floppy you will notice a small hole. This tells the computer if the diskette within the computer is a High Density diskette.
Third, you will notice the circular metal disk in the middle of the floppy diskette. This is used to rotate the magnetic medium within the floppy disk casing.
Fourth, you will see a metal door which can be moved left and then will snap back to its original position. This door is used to allow the read/write head within the floppy drive to have the capability of accessing the magnetic medium within the casing. Once the diskette is removed, this door will snap back into position, helping to prevent anything from getting on the magnetic medium and destroying it.
5 1/4" FLOPPY DISKETTE
Below is a representation of a 5 1/4" floppy commonly used in 1980's and is generally no longer used today. The 5 1/4" floppy diskette was really floppy (flimsy) when compared to the 3.5" floppy diskette.
floppyd3.gif As you can notice in the above illustration, the 5 1/4" floppy does not have many involved components. First, you will notice the Write protection tab which would be present if the diskette allowed information to be written to it. Placing a piece of tape over the hole or if the hole was not present would make the diskette write protected.
Second, you should notice the large hole in the center of the floppy diskette. This hole allowed the platter within the floppy to be rotated allowing the information to be read from the write access hole.
Third, you should notice the Index hole, this hole was the computer's way of knowing where the starting point of the sector was on the diskette by physically having a hole punched in the film disc within the plastic casing.
Finally, you should notice the write access hole. This is the location which information would be read from as the disc within would rotate. However, because there was no protection like that found on the 3.5" floppy diskette, the 5 1/4" floppy diskette was generally protected by placing it within a protective sleeve.
Hope this helps ya/Let us know ,ok Thank you for using fixya.com.Please dont for get to Vote.
Jul 20, 2008 | Dell Inspiron 6400 Notebook
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 8400 PC Desktop Logo
63 people viewed this question
Alun Cox
