Question about Neff U1721 Double circotherm Electric Oven
Please help Fan not working in Neff U1451
Hi there we have just been in our house a month and found that the light has gone and the fan is not working in our Neff double oven, its a Neff U1451..I cant find the fuse to check that and dont know if the bulb blowing are connected...has anyone got any ideas?
Very many thanks
  • sib79 Feb 16, 2009
    Yes we did that before replacing and it seems to be working so far anyways good advice although today it stopped mid way through making bread we will see
  • 32 Answers
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Posted on Feb 15, 2009
  • amgm
    amgm Feb 15, 2009
    Cheers
  • Jean Hooper Mar 15, 2012
    My oven light doesn't work when the oven is on, but does work when oven is off and light switch activated. Also the circotherm is not working.
Need a manual for a neff fan assisted oven
Hi, Same can be found on neff website, Please find the same.
http://www.neff.co.uk/getting-started-with-your-neff-oven.html
Aug 25, 2014 | Neff Ovens
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Oven has stopped heating up
If the fan is working o/k, then it is almost certain to be the element that needs to be replaced
This is located at rear of oven compartment, behind removeable cover.
Please rate my solution.
Thanks.
Nov 22, 2009 | Neff U1421 Double circotherm Electric Oven
My new neff oven b1524 dosn`t get hot the lights are on timer works but no heat??
Hi.
If it is a fan assisted oven, and the fan is working o/k, then you to replace the oven heater element.
Thanks.
Oct 24, 2009 | Neff B1421 Electric Single Oven
The fan system does not heat up the oven
Hi.
If the fan is working o/k, then you need to fit a new oven element. Very common fault on Neff oven's.
Please rate my solutrion.
Thanks.
Jul 19, 2009 | Neff Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Can not remove element
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Apr 02, 2008 | Neff U1721 Double circotherm Electric Oven
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
596 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
