Question about Lexmark X1150 All-In-One InkJet Printer
Lexmark all in one X1150
I cannot print any document only i can scan, please help me
  • johnmokey6 Feb 22, 2009
    printer will just scan not copy onto papper
  • eagle338
    eagle338 May 11, 2010
    Does it show any error message when you try to scan? If yes please post the message here..
    Regards,
    Sai.
Please look at the proble from saxtoncc posted on feb 06 2009. Maybe is this solving you problem
Posted on Feb 14, 2009
A 2inch solid black horizontal band appears when scanning in the top 1/3 of document. same place all the time. it prints as scanned
You have to change the scanning mechanism under the glass. It is pretty trick, but after that it works great.
Apr 02, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Basic instructions for scaning on a lexmark x1150
Using your MSoffice Word (2003/7) you can simply create a New document and then go to Insert / Picture / From scanner or Camera
select TWAIN scanner and satrt scanning from PC (have your document in Lexmark scanner Tray in).
Accept or modify settings.
Resize or change properties of adquired picture
save the Word Document.
You can also use your Picture processing program (Paint or other)
Open Paint (or Other) Go to file /adquire/ select your scanning device Scan.
Dec 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 series all-in-one center
1100 and 1150 drivers are the same thing as far as drivers are concerned for Lexmark machines.
Sep 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
FAX with my Lexmark X1150
you can find a complete .pdf guide thats easy to understand by clicking the link below !
Lexmark X1100 series User Guide.pdf
Worry not , the X1100 series should match your x1150 model installation procedure!
Whatever O/S you use , you can get the Lexmark drivers to match from the Lexmark downloads section for X1100 series below ( also links to other models as well !)
Lexmark X1150 drivers & downloads / Choose your O/S
Jun 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
Scanning leaves a black area on document
Clean the scanner bed with a cloth if you still have the peoblem then unplug power and wait for 30 seconds and plug back and try to scan if you have the same problem then its hardware failure...........
Apr 14, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Nov 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
