Question about Sanyo PLC SW20A Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
Basically, my projector has started powering itself down a split second after it completes its startup countdown. Makes it the full 30 second countdown, displays image for less than a second, then shuts itself off. Neither the "lamp replace" nor "warning temp" light comes on. Is it my lamp? Or something more severe?
  • 93 Answers
Check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Posted on Feb 08, 2009
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
Hello.... Sanyo PLC-SU20N projector....shuts down within 3 seconds of turning on.
If the lamp doesn't strik, it will.
Check the ballast unit and lamp age.
Mar 19, 2011 | Sanyo PLC SU20N Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
We are having one sanyo plc xu 78 projector.when it began to switch it on the count down screen will displays when the count down timing is coming to 0 then its directly going to stand by mode. its not...
The countdown shows while the unit is going through its internal circuit testing. Usually if a problem is found, there will be indications with the standby lights and lamp/temp lights. Are there any other indications here or just the unit going into standby?
Jul 08, 2010 | Sanyo PLC XU35 Multimedia Projector
Projector turns off after 5 seconds
You have a classic temp sensor problem. Its a fail safe on theprojector, basically a fuse that bridges the main power cables. Lookslike a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit getshotter, and thus breaks the power circut. All you need to do is, openup the unit, locate the sensor (its mounted next to the lamp on yourprojector) And push the little white head back down, thus closing thecircut, and restoring power supply.
Here is the full repair schematic to guide you. :)
Jul 12, 2009 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo plc-xu35
Sounds like a simple problem to fix but don't ask here unless you plan on signing up...take your projector to a "real" professional who'll actually speak to you.
Sep 12, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC SW20A Multimedia Projector Logo
563 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
