Question about Global Marketing Partners Office Equipment & Supplies
Can't put selected pictures onto page layouts....
Using Lexmark's photo editor, I can select pictures, but it won't let me move them across to put them onto the page layouts. For example, if I pick an A4 page layout, and want 4 pictures (A6 size) on the page, I can select the 4 pictures, but then it freezes up and won't respond to anything. I have to close the application down.
Ivan Stones
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Print layout for CD
You need a photo editor. plent out there simply do a google.
Posted on Jun 14, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
rcw1962
  • 2571 Answers
SOURCE: When printing in black ink,
Sounds like you need to do a head clean, and run the align tool
Posted on Sep 04, 2010
Lexmark x2650 printing vertical on pages not horizontal why
when you click print, select preferences and then paper layout, choose portrait or landscape there to change the print layout.
Dec 29, 2012 | Lexmark X2650 All-In-One InkJet Printer
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
ONLY A NARROW IMAGE OF A 'SKETCH-UP' WILL PRINT ACROSS THE MIDDLE OF THE PAPER, WHEN I WOULD LIKE A FULL PAGE (BOARDERLESS) IN LANDSCAPE ORIENTATION. WHAT SETTING AM I MISSING?
Before printing, configure the page setup on the application where you're printing from. Go to File -> Page Setup -> select Landscape orientation -> hit OK to save the setting.
To print your sketch, go to File -> Print -> Preferences/Properties -> from the Page Setup tab, select Landscape orientation -> from the Print Layout tab, select Borderless -> click OK to save the settings -> click OK to start printing.
I hope this information has been helpful.
If you need additional assistance, please contact Lexmark technical support.
Nov 24, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
Aug 03, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
I have an HP PHOTOSMART 8250 printer. When I print a photo in the photo tray it only prints part of the photo. How do I remedy this?
Hello, This sounds like a layout problem.
Here's what to do: After you've chosen the photo you'd like to print, make sure you press Layout on the printer control panel to select a layout for that photo. Press the button repeatedly to move through the six layout options. When a memory card is inserted, the selected layout is displayed in the bottom center of the printer screen. All photos selected from the printer control panel will print in the selected layout.
For more information, here's an easily clickable link to the manual for this printer. This link is part of the HP official web site.
http://h10032.www1.hp.com/ctg/Manual/c00378138.pdf
I hope this helps you!
- CBR2009
Aug 09, 2009 | HP Photosmart 8250 InkJet Printer
Lexmark x2470 how do i scan
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Being scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 16, 2008 | Lexmark X2470 All-In-One InkJet Printer
I have a Lexmark x2470 and it works great. But ever since I got it I have never figured out how to scan to computer. Can you help?
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Beig scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
How to start web leyout in photoshop, in details
In Adobe Bridge, select Tools > Photoshop > Web Photo Gallery. (Alternatively, in Photoshop, select: File > Automate > Web Photo Gallery.) The Adobe Web Photo Gallery wizard will open, offering you a myriad of different web page layouts and you can select your preferred style from the 'Styles' dropdown menu. If using Bridge, and you have selected specific images that you want on the page before creating the gallery, you can insert the pictures into your webpage automatically, under the 'Source images' menu, and the 'Use' pull-down menu, choosing, 'Selected images from Bridge,' which should be selected by default. If you need further instructions or run into different problems please let us know.
Hope this will FixYa!!!
Dec 30, 2007 | Adobe Photoshop 7.0 for PC
41 people viewed this question
Top Global Marketing Partners Office Equipment & Supplies Experts
kavinhue
Level 1 Expert
Pravin Gupta
Pravin Gupta
Are you a Global Marketing Partners Office Equipment and Supply Expert? Answer questions, earn points and help others
