Question about Cuisinart DCC-240 Coffee Maker
Cuisinart DCC-240 drip lid came apart, how to reassemble?
Hi, the little lid with a little coil spring came apart and I don't know how to put it all back together! Help!
  • 137 Answers
You may not be able to put it back on, in case you can't it is no bigee, all this does is prevent coffee from running everywhere if you remove the pot before the maker is finished making coffee.
Wait for it to be done and you will just have just a drip or two.
Posted on Feb 08, 2009
Coffee spilling over the top , not dripping
The caraffe lid must be on the Coffee maker while making coffee.
The lid pushes a opens the hut-of valve in the filter.
If the lid is not on the caraffe, the valve will prevent coffee from dripping out of the filter.
This is to prevent coffee leaking on the lower carafe heating element when you remove the caraffe to quickly pour some coffee. the water accumulates while you do this, so if the machine is still brewing, you should put the carafe with lid back in the cofee maker, to release the accumulated liquid in the filter.
Jun 08, 2012 | Cuisinart DCC-1200 Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
The water and coffee grinds sits in the filter, does not drip into the pot
Most modern coffee pots have a feature in them to keep you from spilling coffee all over the place when you want to take a cup of coffee before they finish brewing. It sounds like you are having some issues with yours.
Basically, the way they work is that there is some sort of gasket (rubber disk) that has a lever/spring mechanism that plugs the way out of the filter basket when there isn't a coffee pot under the filter basket. They are designed so that the lid of the coffee pot pushes up on part of the mechanism and forcing the little gasket open. (You can generally figure it out pretty easily by fiddling with it.) It sounds like you may not be assembling the lid on the pot completely (this model has a lid where the dome sticks up) or may be missing the lid all together. It's also possible that a piece of packing material may be clogging this or the gasket could be stuck shut, maybe with dried coffee.
One sign that the assembly is working properly is there is just a little bit of resistance (not very noticable) when you first start putting to pot in place and it makes a clicking/thunking noise when the pot fully seats.
Sep 18, 2009 | Cuisinart DCC-1200 Coffee Maker
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DGB-300 need Grinder Basket Lid. Where can I purchase this part??
Hi There
Firstly I found you a user manual located here http://lib.store.yahoo.net/lib/cuisinart/DGB300.pdf
Also I located this customer care and spare parts site for you, direct to cuisinart and they have a customer care help line im sure they can get your part for you
http://www.cuisinart.co.uk/
Tel 0870 240 6902
they are open Monday - Friday 9am - 5pm
Hope that is helpful
Jul 20, 2009 | Cuisinart DGB-300 Coffee Maker
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
My cuisinart DCC-2000 leaks all over the counter when i make coffee, anyone had a similar problem? i hear rumors that there is tubes inside that can go bad....
Be sure to not overfill the reservoir. Look at the back where the lid hinge is and you will see that the opening is lower then what the tank looks like it can be filled to. Had the same problem and stopped it by being a little more careful when I filled it.
Apr 14, 2009 | Cuisinart DCC-2000
I got a Cuisinart coffee maker DCC 1400C for a wedding present, worked fine, then all of a sudden STOPPED. I did the self clean, and that worked fine, the brew setting doesn't. The water doesn't go...
Unplug for 20 minutes or longer to reset. Make sure the lid is on the caraffe, or the brew basket will be stuck in the closed position. If the water still won't go through, consider ordering a new brew basket, because yours might have a faulty spring.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart DCC-1200 Coffee Maker
How to use Cuisinart DCC-1200 Coffee Maker to make a pot of coffee
Just bought a DCC-1200 from Goodwill for 4.95. Looks brand new. Would heat up and sputter but nothing comming through to the pot. Removed botton with T-10 torx driver. Remove hose with check valve in it. TYou can squeeze the hose about an inch down and feel it to determine which hose its in. Pushed the valve out with a screw driver over a towl so if the little ball fell out I wouldnt loose it. There was a small wad of yelllow paper clogging the valve. Removed it. Reassembled and it works great.
Jul 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-240 Coffee Maker Logo
155 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Tony R.
Tony R.
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
