Possible that there are issues with the drive assembly , check the belt if this is belt driven. Also a failure of the bearings can result in friction which can add up to the motor load to cut off with a heavy load.
Click on Bearings
Finally check the drain pump, check the level of the machine for full drain..
SOURCE: whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
SOURCE: Drum won't spin - especially when full of clothes.
Does it spin without anything in it?
Does it agitate?
Does it pump out the water?
If you said Yes to all of these Im sorry to say this you probably burnt out the clutch.
If it doesnt agitate maybe you will be lucky and you only need a coupler.
If you over load it often and wash large items you probably burnt out the clutch. This is an expense repair. You may want to consider a new washer.
